Check_http plugin gives error 404 or 503 but websites are ok.
Do you have some hints for me ?
Best regards,
Eric.
Command: check_mk_active-http! -I $HOSTADDRESS$ -u ‘/’ -p 80
Best regards,
Eric.
Try troubleshooting with other tools that give you more info. Curl is usually the best choice.
Kind regards,
Matija
From: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de]
On Behalf Of Eric Lecocq
Sent: petek, 27. maj 2016 13:11
Subject: [Check_mk (english)] Check_http plugin gives 404 or 503 but websites are ok
Best regards,
Eric.
Hi Eric,
did you try param “follow redirection”? What does “~/lib/nagios/plugins/check_http -I IPADDRESSOFHOST -u ‘/’ -p 80 -v” report (the “-v” param can be provided multiple times to get more output)?
Regards,
Marcel
Eric Lecocq Eric.Lecocq@prodata-systems.be schrieb am Fr., 27. Mai 2016 um 13:12 Uhr:
Best regards,
Eric.
checkmk-en mailing list
Finally,
It’s the following command :
ð
HTTP CRITICAL: HTTP/1.1 503 Service Temporarily Unavailable - 4080 bytes in 0.025 second response time
From: Marcel Schulte [mailto:schulte.marcel@gmail.com]
Sent: vendredi 27 mai 2016 13:25
To: Eric Lecocq Eric.Lecocq@prodata-systems.be; checkmk-en@lists.mathias-kettner.de
Subject: Re: [Check_mk (english)] Check_http plugin gives 404 or 503 but websites are ok
Hi Eric,
Regards,
Marcel
Best regards,
Eric.
I want try this command but it’s not working !
Sent: vendredi 27 mai 2016 14:50
To: Marcel Schulte schulte.marcel@gmail.com; checkmk-en@lists.mathias-kettner.de
Finally,
ð
Hi Eric,
Regards,
Marcel
Best regards,
Eric.
Hi Eric,
I requested the below command output, please check that.
Regards,
Marcel
Marcel Schulte schulte.marcel@gmail.com schrieb am Fr., 27. Mai 2016 13:24:
Hi Eric,
Regards,
Marcel
Best regards,
Eric.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.05.30 12:14:55 =~=~=~=~=~=~=~=~=~=~=~=
./check_http -I www.prod
data-healthcare.be -u ‘/’ -p 80 -v
GET / HTTP/1.0
User-Agent: check_http/v2.1.1 (monitoring-plugins 2.1.1)
Connection: close
http://www.prodata-healthcare.be:80/ is 389 characters
STATUS: HTTP/1.1 403 Forbidden
**** HEADER ****
psbelmo_2016-05-30_121455.log (995 Bytes)
psbelmo_2016-05-30_121644.log (7.1 KB)
Regards,
Marcel
Hi Eric,
Regards,
Marcel
Best regards,
Eric.
Hi Eric,
the debug output shows the webserver response: 403.
You’ll have to analyse what happens when you call the website in your browser (eg by tracing in wireshark). When you know what happens you should have a clue how to configure your active http check…
Regards,
Marcel
Eric Lecocq Eric.Lecocq@prodata-systems.be schrieb am Mo., 30. Mai 2016 um 12:22 Uhr: > =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.05.30 12:14:55 =~=~=~=~=~=~=~=~=~=~=~=
GET / HTTP/1.0
Connection: close
**** HEADER ****
Date: Mon, 30 May 2016 10:14:57 GMT
Server: Apache
Vary: Accept-Encoding
Content-Length: 202
Connection: close
Content-Type: text/html; charset=iso-8859-1
**** CONTENT ****
403 Forbidden
Forbidden
You don't have permission to access /
on this server.
HTTP WARNING: HTTP/1.1 403 Forbidden - 389 bytes in 0.033 second response time |time=0.033041s;;;0.000000 size=389B;;;0
]0;helpdesk@psbelmo: /omd/versions/1.30/lib/nagios/pluginshelpdesk@psbelmo:/omd/versions/1.30/lib/nagios/plugins$ exit
logout
Sent: lundi 30 mai 2016 11:11
Hi Eric,
Regards,
Marcel
Hi Eric,
Regards,
Marcel
Best regards,
Eric.
Ok thx
Hi Eric,
Regards,
Marcel
./check_http -I
www.prod
GET / HTTP/1.0
Connection: close
is 389 characters
**** HEADER ****
Server: Apache
Content-Length: 202
Connection: close
**** CONTENT ****
403 Forbidden
Forbidden
on this server.
size=389B;;;0
logout
Subject:
Hi Eric,
Regards,
Marcel
Hi Eric,
more output)?
Regards,
Marcel
Best regards,
Eric.
Some web sites don't have an index file in the root dir and don't allow
directory listings. If a browser pointed at the root dir is ending up
somewhere else, you can either have the check go directly to the
destination or figure out how the browser is getting there. If it's
not using html (javascript or something else) the simple check
may not be able to emulate the browser well enough to test
the root directory...so you would have to give it something else
to look at...like a known page, or add a small html file that
check_mk can read.
From: Eric Lecocq [mailto:Eric.Lecocq@prodata-systems.be]
Sent: jeudi 2 juin 2016 15:05
Cc: Jam Mulch <spammagnet10@gmail.com>
Subject: FW: [Check_mk (english)] Check_http plugin gives 404 or 503 but websites are ok
Sent: jeudi 2 juin 2016 14:55
To: Jam Mulch <spammagnet10@gmail.com<mailto:spammagnet10@gmail.com>>
Cc: checkmk-en@lists.mathias-kettner.de<mailto:checkmk-en@lists.mathias-kettner.de>
Subject: RE: [Check_mk (english)] Check_http plugin gives 404 or 503 but websites are ok
We had the same assumptions.
But today we tested the command
~/lib/nagios/plugins/check_http -H ADDRESSOFHOST -u '/' -p 80 -
v" report
iso
"~/lib/nagios/plugins/check_http -I IPADDRESSOFHOST -u '/' -p 80 -v" report
It gives better results.
But now to get this check_mk
Site alias
Hostname
www.prodata-systems.be<http://172.22.2.23/psbe/check_mk/view.py?view_name=hoststatus&host=www.prodata-systems.be>
Service description
HTTP internet port 80<http://172.22.2.23/psbe/check_mk/view.py?view_name=servicedesc&service=HTTP%20internet%20port%2080>
Service icons
Service state
CRIT
Servicegroups the service is member of
Service service level
Service contact groups
check-mk-notify, all
Service contacts
check-mk-notify, helpdesk
Output of check plugin
HTTP CRITICAL - No data received from host
Long output of check plugin (multiline)
Service performance data
Service Perf-O-Meter
Service check command
check_mk_active-http! -I $HOSTADDRESS$ -H '%HOSTADDRESS%'
Service normal/retry check interval
60s/60s
Current check attempt
1/1
Service notification number
1
Service check type
ACTIVE
The age of the current service state
2016-05-27 11:51:23
The last time the service was OK
1970-01-01 01:00:00
The time since the last check of the service
35 sec
The time of the next scheduled service check
in 24 sec
The time of the next service notification
2016-05-27 11:51:24
The time of the last service notification
2016-05-27 11:51:24
Service check latency
0.240 sec
Service check duration
0.026 sec
Currently in downtime
no
In notification period
yes
Service notification period
24X7
Service alternative display name
Service custom variables
Check manual (for Check_MK based checks)
Custom services notes
PNP service graph
Best regards,
Eric.
Sent: lundi 30 mai 2016 16:27
To: Eric Lecocq <Eric.Lecocq@prodata-systems.be<mailto:Eric.Lecocq@prodata-systems.be>>
On 5/30/2016 10:15 AM, Eric Lecocq wrote:
Ok thx
Sent: lundi 30 mai 2016 14:19
To: Eric Lecocq <Eric.Lecocq@prodata-systems.be><mailto:Eric.Lecocq@prodata-systems.be>; checkmk-en@lists.mathias-kettner.de<mailto:checkmk-en@lists.mathias-kettner.de>
Hi Eric,
You'll have to analyse what happens when you call the website in your browser (eg by tracing in wireshark). When you know what happens you should have a clue how to configure your active http check...
Regards,
Marcel
Eric Lecocq <Eric.Lecocq@prodata-systems.be<mailto:Eric.Lecocq@prodata-systems.be>> schrieb am Mo., 30. Mai 2016 um 12:22 Uhr: =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.05.30 12:14:55 =~=~=~=~=~=~=~=~=~=~=~=
./check_http -I www.prod<http://www.prod>
data-healthcare.be<http://data-healthcare.be> -u '/' -p 80 -v
GET / HTTP/1.0
Connection: close
**** HEADER ****
Server: Apache
Content-Length: 202
Connection: close
**** CONTENT ****
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>403 Forbidden</title>
</head><body>
<h1>Forbidden</h1>
<p>You don't have permission to access /
on this server.</p>
</body></html>
]0;helpdesk@psbelmo: /omd/versions/1.30/lib/nagios/pluginshelpdesk@psbelmo:/omd/versions/1.30/lib/nagios/plugins$<mailto:/omd/versions/1.30/lib/nagios/pluginshelpdesk@psbelmo:/omd/versions/1.30/lib/nagios/plugins$> exit
logout
To: Eric Lecocq <Eric.Lecocq@prodata-systems.be<mailto:Eric.Lecocq@prodata-systems.be>>; checkmk-en@lists.mathias-kettner.de<mailto:checkmk-en@lists.mathias-kettner.de>
Hi Eric,
Regards,
Marcel
Marcel Schulte <schulte.marcel@gmail.com<mailto:schulte.marcel@gmail.com>> schrieb am Fr., 27. Mai 2016 13:24:
Hi Eric,
did you try param "follow redirection"? What does "~/lib/nagios/plugins/check_http -I IPADDRESSOFHOST -u '/' -p 80 -v" report (the "-v" param can be provided multiple times to get more output)?
Regards,
Marcel
Eric Lecocq <Eric.Lecocq@prodata-systems.be<mailto:Eric.Lecocq@prodata-systems.be>> schrieb am Fr., 27. Mai 2016 um 13:12 Uhr:
Best regards,
Eric.
Command: check_mk_active-http! -I $HOSTADDRESS$ -u '/' -p 80
HOSTS: www.prodata-systems.be<http://www.prodata-systems.be>, www.prodata-healthcare.be<http://www.prodata-healthcare.be>
As check_mk_active-http make use of check_http, I tried the command
-H ADDRESSOFHOST
-u ‘/’ -p 80 –
v" report
iso
But how to get this check_mk
Site alias
Hostname
Service description
Service icons
Service state
CRIT
Service contacts
-I $HOSTADDRESS$ -H ‘%HOSTADDRESS%’
Sent: lundi 30 mai 2016 11:09
To: Eric Lecocq Eric.Lecocq@prodata-systems.be; Marcel Schulte schulte.marcel@gmail.com; checkmk-en@lists.mathias-kettner.de
Finally,
ð
Hi Eric,
Regards,
Marcel
Best regards,
Eric.
