i’m facing the following problem : we monitor our checkpoint server running on HPE server with check_mk 1.4.0p25 (ubuntu 16.04).
all temp + fans checks give the data but says “sensor out of range”….
Can you help me ?
Best regards,
Eric
Can you help me ?
Best regards,
Eric
Hi Eric,
From which check plugin do you receive the error message?
I think this is the important question to give you some help.
Best regards
Andreas
Eric Lecocq Eric.Lecocq@prodata-systems.be schrieb am Mo., 19. Feb. 2018, 16:54:
Can you help me ?
Best regards,
Eric
checkmk-en mailing list
Builtin checkpoint checks (under checks/checkpoint_temps.)
It seems that SNMP data are relayed correctly ans it’s checkpoint self that gives this info.
Best regards,
Éric
Hi Eric,
Best regards
Andreas
Can you help me ?
Best regards,
Eric
Ok if it is an HPE server it is better to monitor the hardware health over iLO port und disable the internal hardware health check from checkpoint. (Inside check_mk)
It is possible that there are no correct data available.
Best regards
Andreas
Eric Lecocq Eric.Lecocq@prodata-systems.be schrieb am Di., 20. Feb. 2018, 23:28:
Best regards,
Éric
Hi Eric,
Best regards
Andreas
Can you help me ?
Best regards,
Eric
