[Check_mk (english)] check_mk_active-ldap with v3 startTLS - Could not init startTLS at port 389!
Have some new ldap servers running v3 and
startTLS.
The ldapsearch command outside of check_mk
works fine e.g.
ldapsearch -LL -v -D “cn=Manager,dc=xxxx,dc=xxxxx,dc=com”
-p 389 -h n000a451.ixxxx.xxxxx.com -b “dc=xxxx,dc=xxxxxxxx,dc=com”
-s sub -x -ZZ “(objectclass=*)” -v -W
ldap_initialize( ldap://n000a451.xxxx.xxxxxxx.com:389
Enter LDAP Password:
filter: (objectclass=*)
requesting: All userApplication attributes
version: 1
but inside check_mk it fails
check_mk_active-ldap! -b ‘dc=xxxx,dc=xxxxxx,dc=com’
-t 10 -D ‘cn=Manager,dc=xxxx,dc=xxxxxx,dc=com’ -p 389 -3 -T
gives
Now my investigation shows this is probably
due to a certificate issue but only within check_mk. the ca certs are setup
(as shown by the ldapsearch command working).
I think check_mk_active-ldap can’t find
the /etc/openldap/cert dir or /etc/openldap/ldap.conf file, probably due
to an environment variable being ‘missing’
I am using OMD 1.30 (rather then straight
check_mk).
Any suggestions what and how to put
in to make it see the right environment. Maybe a bit like this guy did
for nagios/icinga (https://nagios-plugins.org/archive/help/2011-September/006241.html)
but for check_mk?
Not sure what I need to change here.
Thanks
Ben
For ICDS, AICS, DST, project, infrastructure,
consultancy or cloud support please use the ICDS Task ID : 3ADMTECH@uk.ibm.com
Unless stated otherwise above:
IBM United Kingdom Limited - Registered in England and Wales with number
741598.
Registered office: PO Box 41, North Harbour, Portsmouth, Hampshire PO6
3AU
We normally use 389 for non-ssl/tls connections and 636 for ssl/tls.
Your example suggests that is what ldapsearch is doing as well:
()� NOTE:ldap vs ldaps
You should be able to verify by upping the ldapsearch debug level
and looking for secure connection handshaking.
(or is it the verbose level…or both…don’t remember offhand)
ldap://****:389
  On 11/16/2016 09:16 AM, Ben Shade
wrote:
    Have some new ldap
startTLS.
check_mk
works fine e.g.
          ldapsearch -LL �-v -D
    ldap_initialize(
attributes
  version: 1
-t 10 -D ‘cn=Manager,dc=xxxx,dc=xxxxxx,dc=com’ �-p 389 -3 -T
  gives
389!
is probably
certs are setup
can’t find
probably due
straight
check_mk).
put
guy did
for nagios/icinga (https://nagios-plugins.org/archive/help/2011-September/006241.html )
but for check_mk?
here.
  Thanks
  Ben
infrastructure,
with number
741598.
Hampshire PO6
3AU
checkmk-en mailing list
ldap://n000a451.xxxx.xxxxxxx.com:389checkmk-en@lists.mathias-kettner.dehttp://lists.mathias-kettner.de/mailman/listinfo/checkmk-en
AD doesn't support STARTTLS so you need to use LDAPS directly.
You can get around the certificate by setting the environment variable
LDAPTLS_REQCERT=allow, which will cause ldapsearch to ignore a "bad"
certificate. See ldap.conf man page for details.
Later,
Darin
On Wed, Nov 16, 2016 at 9:16 AM, Ben Shade <benjamin_shade@uk.ibm.com> wrote:
Have some new ldap servers running v3 and startTLS.
The ldapsearch command outside of check_mk works fine e.g.
ldapsearch -LL -v -D "cn=Manager,dc=xxxx,dc=xxxxx,dc=com" -p 389 -h
n000a451.ixxxx.xxxxx.com -b "dc=xxxx,dc=xxxxxxxx,dc=com" -s sub -x -ZZ
"(objectclass=*)" -v -W
ldap_initialize( ldap://n000a451.xxxx.xxxxxxx.com:389 )
version: 1
check_mk_active-ldap! -b 'dc=xxxx,dc=xxxxxx,dc=com' -t 10 -D
'cn=Manager,dc=xxxx,dc=xxxxxx,dc=com' -p 389 -3 -T
gives
Now my investigation shows this is probably due to a certificate issue but
only within check_mk. the ca certs are setup (as shown by the ldapsearch
command working).
I think check_mk_active-ldap can't find the /etc/openldap/cert dir or
/etc/openldap/ldap.conf file, probably due to an environment variable being
'missing'
I am using OMD 1.30 (rather then straight check_mk).
Any suggestions what and how to put in to make it see the right environment.
Maybe a bit like this guy did for nagios/icinga
([Nagiosplug-help] check_ldap tls negotiation failed but only inside Nagios) but for
check_mk?
Thanks
Ben
For ICDS, AICS, DST, project, infrastructure, consultancy or cloud support
741598.
Registered office: PO Box 41, North Harbour, Portsmouth, Hampshire PO6 3AU
Thanks, but the port is correct using 389.
startTLS is used after initial connection (unsecured) to 389 and the startTLS
is initiated. ldaps (636) is deprecated for openldap (not sure I agree
with that but thats a different discussion).
Native linux ldapsearch works as expected…but
checK_mk_active-ldap does not, so I think it is an environment variabe
in checK_mk (omd) that is not set right. Also not sure (for checK_mk_active-ldap)
how to turn on extra debug/verbose levels. I can (and have) turned them
on for ldapsearch but that works fine.
Ben
Jam Mulch spammagnet10@gmail.com
To:
Ben Shade/UK/IBM@IBMGB,
Date:
16/11/2016 16:32
Subject:
Re: [Check_mk
at port 389!
for ssl/tls.
(ldap://****:389)
NOTE:ldap vs ldaps
You should be able to verify by upping the ldapsearch debug level and looking
and startTLS.
version: 1
check_mk_active-ldap! -b ‘dc=xxxx,dc=xxxxxx,dc=com’ -t 10 -D ‘cn=Manager,dc=xxxx,dc=xxxxxx,dc=com’
-p 389 -3 -T
gives
but only within check_mk. the ca certs are setup (as shown by the ldapsearch
command working).
I think check_mk_active-ldap can’t find the /etc/openldap/cert dir or /etc/openldap/ldap.conf
file, probably due to an environment variable being ‘missing’
Maybe a bit like this guy did for nagios/icinga (https://nagios-plugins.org/archive/help/2011-September/006241.html)
but for check_mk?
Thanks
Ben
741598.
3AU
`_______________________________________________
[http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en`](http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en)
741598.
3AU
Thanks, this is not windows/AD but a Redhat
openldap server (and in this particular case a Redhat client) and I have
proven startTLS works in multiple way (ldapsearch including on the same
check_mk/omd server, but I can’t get check_mk_active-ldap to work (and
suspect env variable is the issue). I could try the LDAPTLS_REQCERT=allow
(but don’t want to really leave this on) but even to try it, I am not sure
where the environment variable goes so that check_mk_active-ldap will use
it? (it is not needed for ldap search as that works fine with startTLS)
Any ideas?
Ta
Ben
Darin Perusich darin@darins.net
To:
Cc:
Date:
16/11/2016 17:01
Subject:
Re: [Check_mk
at port 389!
`AD doesn’t support STARTTLS so you need to use LDAPS
directly.
LDAPTLS_REQCERT=allow, which will cause ldapsearch to ignore a “bad”
Later,
Darin
-p 389 -h
-s sub -x -ZZ
version: 1
gives
but
command working).
or
being
‘missing’
([https://nagios-plugins.org/archive/help/2011-September/006241.html`]([Nagiosplug-help] check_ldap tls negotiation failed but only inside Nagios)`)
but for
check_mk?
Thanks
Ben
support
number
PO6 3AU
[http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en`](http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en)`
741598.
3AU
Did a bit of command line checking and
using
./check_ldap -v -H n000a451 -b
‘dc=xxxx,dc=xxxxxxxxx,dc=com’ -t 10 -p 636 -3
it fails with
ldap_bind: Can’t contact LDAP server
(-1)
additional info: TLS: hostname
does not match CN in peer certificate
Could not bind to the LDAP server
but
./check_ldap -v -H n000a451.xxxx.xxxxxxxx.com
-b ‘dc=xxxx,dc=xxxxxxxxx,dc=com’ -t 10 -p 636 -3
(i.e FQDN) works.
So the shortname passed from check_mk
as the hostname will always fail, unless I can get it to pass the FQDN
(which check_mk does not know I don’t think - unless I add a field)
So looks like a change needed in check_mk
(to allow the WATO/GUI configuration to do this, and potentially have the
FQDN) and (nagios) check_ldap to get this to work with new arguements :frowning:
Will look at other ways of doing this…probably
a simpler check of some kind.
Ben
To:
Cc:
Date:
17/11/2016 10:06
Subject:
Re: [Check_mk
at port 389!
Sent by:
checkmk-en-bounces@lists.mathias-kettner.de
Redhat openldap server (and in this particular case a Redhat client) and
I have proven startTLS works in multiple way (ldapsearch including on the
same check_mk/omd server, but I can’t get check_mk_active-ldap to work
(and suspect env variable is the issue). I could try the LDAPTLS_REQCERT=allow
Any ideas?
Ta
Ben
To: Ben
Shade/UK/IBM@IBMGB
Cc: “checkmk-en@lists.mathias-kettner.de
Date: 16/11/2016
17:01
Subject: Re:
AD doesn’t support STARTTLS so you need to use LDAPS directly.
Later,
Darin
-p 389 -h
-s sub -x -ZZ
version: 1
gives
but
command working).
or
being
‘missing’
but for
check_mk?
Thanks
Ben
support
number
PO6 3AU
741598.
3AU`_______________________________________________
741598.
3AU
So…simplest fix is to stop checking the
cert so add
TLS_REQCERT never
to the end of /etc/openldap/ldap.conf
So the check now ignore the certificate
‘issues’ (not good but better than failing) but is now green/OK.
Hope that helps someone else.
Ben
To:
Date:
17/11/2016 13:44
Subject:
Re: [Check_mk
at port 389!
Sent by:
using
./check_ldap -v -H n000a451 -b ‘dc=xxxx,dc=xxxxxxxxx,dc=com’ -t 10 -p
636 -3
it fails with
ldap_bind: Can’t contact LDAP server (-1)
additional info: TLS: hostname does not match CN in peer certificate
but
./check_ldap -v -H n000a451.xxxx.xxxxxxxx.com -b ‘dc=xxxx,dc=xxxxxxxxx,dc=com’
-t 10 -p 636 -3
(i.e FQDN) works.
So the shortname passed from check_mk as the hostname will always fail,
unless I can get it to pass the FQDN (which check_mk does not know I don’t
So looks like a change needed in check_mk (to allow the WATO/GUI configuration
to do this, and potentially have the FQDN) and (nagios) check_ldap to get
Will look at other ways of doing this…probably a simpler check of some
kind.
Ben
Shade/UK/IBM@IBMGB
To: Darin
Date: 17/11/2016
10:06
Subject: Re:
Sent by: checkmk-en-bounces@lists.mathias-kettner.de
Thanks, this is not windows/AD but a Redhat openldap server (and in this
particular case a Redhat client) and I have proven startTLS works in multiple
way (ldapsearch including on the same check_mk/omd server, but I can’t
get check_mk_active-ldap to work (and suspect env variable is the issue).
I could try the LDAPTLS_REQCERT=allow (but don’t want to really leave this
on) but even to try it, I am not sure where the environment variable goes
so that check_mk_active-ldap will use it? (it is not needed for ldap search
Any ideas?
Ta
Ben
To: Ben
Shade/UK/IBM@IBMGB
Date: 16/11/2016
17:01
Subject: Re:
Later,
Darin
-p 389 -h
-s sub -x -ZZ
version: 1
gives
but
command working).
or
being
‘missing’
but for
check_mk?
Thanks
Ben
support
number
PO6 3AU
741598.
checkmk-en@lists.mathias-kettner.de`
741598.
741598.
3AU
Setting that globally is probably a BAD idea, then your server will
implicitly trust all certificates even if they are bad. In the OMD or
Nagios users home directory create a ldaprc or .ldaprc and set
TLS_REQCERT=allow|never|try so it only applies to that users sessions,
and doesn't potentially compromise your server. See the man page for
ldap.conf for all the details.
Later,
Darin
On Thu, Nov 17, 2016 at 8:51 AM, Ben Shade <benjamin_shade@uk.ibm.com> wrote:
So...simplest fix is to stop checking the cert so add
TLS_REQCERT never
So the check now ignore the certificate 'issues' (not good but better than
Ben
Date: 17/11/2016 13:44
Subject: Re: [Check_mk (english)] check_mk_active-ldap with v3
Did a bit of command line checking and using
./check_ldap -v -H n000a451 -b 'dc=xxxx,dc=xxxxxxxxx,dc=com' -t 10 -p 636 -3
it fails with
ldap_bind: Can't contact LDAP server (-1)
but
(i.e FQDN) works.
unless I can get it to pass the FQDN (which check_mk does not know I don't
configuration to do this, and potentially have the FQDN) and (nagios)
Will look at other ways of doing this...probably a simpler check of some
kind.
Ben
To: Darin Perusich <darin@darins.net>
Cc: "checkmk-en@lists.mathias-kettner.de"
<checkmk-en@lists.mathias-kettner.de>
Date: 17/11/2016 10:06
multiple way (ldapsearch including on the same check_mk/omd server, but I
can't get check_mk_active-ldap to work (and suspect env variable is the
issue). I could try the LDAPTLS_REQCERT=allow (but don't want to really
leave this on) but even to try it, I am not sure where the environment
variable goes so that check_mk_active-ldap will use it? (it is not needed
Any ideas?
Ta
Ben
To: Ben Shade/UK/IBM@IBMGB
Date: 16/11/2016 17:01
Later,
Darin
On Wed, Nov 16, 2016 at 9:16 AM, Ben Shade <benjamin_shade@uk.ibm.com> > wrote:
version: 1
gives
command working).
being
'missing'
environment.
for
check_mk?
Thanks
Ben
741598.
741598.
3AU_______________________________________________
741598.
741598.
