Hi Romeo,
Thanks for the response. I can snmpwalk from the command line of the host running Nagios (with check_mk) to an example monitored host:
snmpwalk -Os -c public -v 1 njpmedia03 system
sysDescr.0 = STRING: Linux njpmedia03 2.6.32-279.el6.x86_64 #1 SMP Wed Jun 13 18:24:36 EDT
2012 x86_64
sysObjectID.0 = OID: netSnmpAgentOIDs.10
sysUpTimeInstance = Timeticks: (2419574362) 280 days, 1:02:23.62
sysContact.0 = STRING: Root root@localhost (configure /etc/snmp/snmp.local.conf)
sysName.0 = STRING: njpmedia03
sysLocation.0 = STRING: Unknown (edit /etc/snmp/snmpd.conf)
sysORLastChange.0 = Timeticks: (28) 0:00:00.28
sysORID.1 = OID: snmpMPDMIBObjects.3.1.1
sysORID.2 = OID: usmMIBCompliance
sysORID.3 = OID: snmpFrameworkMIBCompliance
sysORID.4 = OID: snmpMIB
sysORID.5 = OID: tcpMIB
sysORID.6 = OID: ip
sysORID.7 = OID: udpMIB
sysORID.8 = OID: vacmBasicGroup
sysORDescr.1 = STRING: The MIB for Message Processing and Dispatching.
sysORDescr.2 = STRING: The MIB for Message Processing and Dispatching.
sysORDescr.3 = STRING: The SNMP Management Architecture MIB.
sysORDescr.4 = STRING: The MIB module for SNMPv2 entities
sysORDescr.5 = STRING: The MIB module for managing TCP implementations
sysORDescr.6 = STRING: The MIB module for managing IP and ICMP implementations
sysORDescr.7 = STRING: The MIB module for managing UDP implementations
sysORDescr.8 = STRING: View-based Access Control Model for SNMP.
sysORUpTime.1 = Timeticks: (28) 0:00:00.28
sysORUpTime.2 = Timeticks: (28) 0:00:00.28
sysORUpTime.3 = Timeticks: (28) 0:00:00.28
sysORUpTime.4 = Timeticks: (28) 0:00:00.28
sysORUpTime.5 = Timeticks: (28) 0:00:00.28
sysORUpTime.6 = Timeticks: (28) 0:00:00.28
sysORUpTime.7 = Timeticks: (28) 0:00:00.28
sysORUpTime.8 = Timeticks: (28) 0:00:00.28
I simply want to get check_mk’s hp_proliant_raid SNMP to detect every host connected to it. I thought I have everything all set up but when I go into WATO for the Nagios host and select agent type to Dual: Check_MK
Agent +SNMP I am not seeing additional checks come up for the raid.
Thanks,
Pete
From: Romeo Guerrero [mailto:rguerrero@stratifihealth.com]
Sent: Tuesday, February 16, 2016 3:01 PM
To: Gizzi, Peter; checkmk-en@lists.mathias-kettner.de
Subject: RE: Check_MK and HP-Proliant_Raid SNMP
Hi Peter,
I have been following your thread loosely, since last Thursday, I believe. I may have missed it, but I don’t see what troubleshooting steps you have done.
Also, if I misunderstood you please forgive me, but in a previous post, you said you are “…trying to receive SNMP from hosts ”. I wanted to clarify, are you wanting SNMP traps,
or are we talking about SNMP polling here? They each work a little differently so I wanted to be clear.
If we are talking about polling, have you tried doing an SNMP walk from the command line?
Thanks,
Romeo Guerrero
Senior Network Engineer
StratiFi Health
6400 Pinecrest Dr., Suite 300
Plano, TX 75024
http://www.stratifihealth.com
The information transmitted is intended only for the person or entity to which it is addressed and
may contain confidential and / or privileged material. Any review, transmission, dissemination or
other use of, or taking of any action in reliance upon, this information by persons, or entities other
than the intended recipient, is prohibited. If you received this in error, please contact the sender
and delete the material from any computer in your company.
checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de]
On Behalf Of Gizzi, Peter
Sent: Tuesday, February 16, 2016 1:51 PM
Subject: [Check_mk (english)] Check_MK and HP-Proliant_Raid SNMP
I’ve gotten a couple of responses to my first request for some insight into getting check_mk to pick up SNMP for failing HP raid but not any closer to making it happen.
Right now I am using check_cciss and check_hpasm but do not want to use this method going forward – simply want to capture SNMP into check_mk itself. As I mentioned, I have hp_health, hp_snmp_agents, etc. installed and when I go to save
and test in check_mk, I am seeing nothing in SNMP being picked up for these alerts.
I configured snmp correctly, have prerequisite packages and even installed all HP MIBs…can someone point me as to what I’ve neglected in getting this to work?
Many thanks,
Pete
