Did any of you had a chance or an use case where in a service ‘x’ goes down in check mk console and as a part of auto healing process , check mk should send contact puppet to do the auto healing of the service which was down.(I also understand that check mk has event handling capability too but however we wanted to leverage puppet as well in auto handling scenario .
All I need to know is can check mk invokes puppet to perform some action .
If yes do we have an api where in check mk talks to puppet ?
auto healing can cause problems.
So please ensure that you get informations when an action is triggered.
Ralf
Am 21.01.2019 um 20:51 schrieb Nagios CMK:
Hi Community
Did any of you had a chance or an use case where in a service 'x' goes down in check mk console and as a part of auto healing process , check mk should send contact puppet to do the auto healing of the service which was down.(I also understand that check mk has event handling capability too but however we wanted to leverage puppet as well in auto handling scenario .
