[Check_mk (english)] check_mk-df - Alert on Inode Warn and Crit
Howdy,
We had a file system that recently went from 50% to 100% of available inodes consumed over the period of a couple of months.
Check_MK didn’t generate any alerts regarding inode consumption and reported status OK during the entire timeframe. I can see the historical data in the graphs that it accurately tracked the consumption of
inodes over time, just didn’t alert.
Is there any way to get the check_mk-df check to alert for inode consumptions?
Mike Hanby
mhanby @ uab.edu
Systems Analyst II - Enterprise
Research Computing Services / IT Infrastructure
The University of Alabama at Birmingham
HI Mike,
Which version are you using? I recall in 1.2.4 ish I wrote my own plugin for inode usage. I am now on 1.2.8 with WATO and the filesystem check supports inode monitoring and thresholds.
Paul
On Mon, Mar 20, 2017 at 7:49 AM, Hanby, Mike mhanby@uab.edu wrote:
Howdy,
Mike Hanby
mhanby @ uab.edu
checkmk-en mailing list
Hi Mike,
Did you specify thresholds for inodes already?
There are no default thresholds for inode usage, so you will have to
create a rule for this.
Regards,
Evy
On Mon, Mar 20, 2017 at 02:49:34PM +0000, Hanby, Mike wrote:
Howdy,
Check_MK didn't generate any alerts regarding inode consumption and reported
graphs that it accurately tracked the consumption of inodes over time, just
didn't alert.
Mike Hanby
mhanby @ uab.edu
Thanks Evy, that’s it. I hadn’t defined any thresholds for inodes.
Sent: Tuesday, March 21, 2017 3:05:43 AM
To: Hanby, Mike
Subject: Re: [Check_mk (english)] check_mk-df - Alert on Inode Warn and Crit
Hi Mike,
Regards,
Evy
Howdy,
didn’t alert.
Mike Hanby
mhanby @ uab.edu
checkmk-en Info Page - Mathias Kettner
This list is intended for discussion between users check_mk. To see the collection of prior postings to the list, visit the checkmk-en Archives.
Howdy Paul,
I’m currently on 1.2.7p2 but migrating to a new instance that is running the latest 1.2.8.
I think the issue is the result of not specifying thresholds as Evy mentioned.
Thanks,
Mike
Sent: Tuesday, March 21, 2017 12:05:04 AM
To: Hanby, Mike
HI Mike,
Paul
Howdy,
Mike Hanby
mhanby @
uab.edu
