[Check_mk (english)] Check-mk Installation - wget and yum errors on installation of check-mk
Hello guys,
A new kid on the block here – so learning a lot.
I stumble upon the same issue again and again, using various online tutorials. I’m using CentOS 7 and this tutorials:
https://spearhead.systems/blog/Tutorial_how_to_install_Check_Mk/ and
http://blog.kevintijssen.eu/how-to-install-check_mk-on-centos-7/
In both case there is a sudo yum install command or a sudo wget command involved to install check-mk. It refers in both tutorials to specific versions – in both versions it gives me a error 404:
Wget error
Yum error
‘Package not available’
Regardless of the versions i use. The current version is listed in the two screenshots above – if i use the versions in the tutorials, the same errors appear.
So, what is going wrong?
Thanks in advance
Verzonden vanuit
Mail
voor Windows 10
Get the download directly from the download page on the support site.
On Fri, Oct 19, 2018 at 08:56 Sven Willemen sven.willemen@outlook.com wrote:
Hello guys,
Wget error
Yum error
Thanks in advance
Verzonden vanuit
Mail
voor Windows 10
checkmk-en mailing list
https://mathias-kettner.com/download.php?
Hello guys,
Wget error
Yum error
Thanks in advance
Verzonden vanuit
Mail
voor Windows 10
Hi Sven,
Try using the command 'curl -O <URL>' instead of wget. This seems to work for us quite well:
curl -O https://mathias-kettner.de/support/1.5.0p6/check-mk-raw-1.5.0p6-el7-38.x86_64.rpm
Cheers,
Marius
On 19 Oct 2018, at 18:55, Sven Willemen <sven.willemen@outlook.com<mailto:sven.willemen@outlook.com>> wrote:
Hello guys,
I stumble upon the same issue again and again, using various online tutorials. I’m using CentOS 7 and this tutorials: https://spearhead.systems/blog/Tutorial_how_to_install_Check_Mk/ andhttp://blog.kevintijssen.eu/how-to-install-check_mk-on-centos-7/
Wget error
<C2FACBE4360343499AFCC617A85DD991.png>
Yum error
<5DDB759B2C8042AB802FEE7E0F2AC4BD.png>
Thanks in advance
Verzonden vanuit Mail<https://go.microsoft.com/fwlink/?LinkId=550986> voor Windows 10
checkmk-en@lists.mathias-kettner.de<mailto:checkmk-en@lists.mathias-kettner.de>
