[Check_mk (english)] CheckMK does not display services for Solaris Node
I installed check_mk agent on a Solaris node, and I am able to see a full output when I telnet localhost.
The node is also successfully integrated to the check_mk monitoring tool.
However, when I run cmk –I from the check_mk monitoring node, there is no output.
And from the monitoring tool, nothing but 2 services : Check_MK Discovery (state OK) and PING (state WARN) are displayed.
The error message (Status detail) for PING is “(No output on stdout) stderr: Traceback (most recent call last):”.
How do I start to troubleshoot? And how do I resolve this error?
Regards,
Aigini
Hi Aigini,
output.
You can make the output for the service discovery more verbose by
running cmk -vvvI --debug.
Also, what version of Check_MK are you running? And what version of the
Check_MK agent?
Regards,
Evy
Hello Evy,
This is the output I get from the debug command :
[root@L28falcon agents]# cmk -vvvI --debug L17pvs2a
Discovering services on L17pvs2a:
L17pvs2a:
Connecting via TCP to 10.97.129.87:6556.
  nothing new
And the version of check_mk tool is the same as the check_mk agent, which is
1.2.6p5.
Regards,
Aigini
-----Original Message-----
From: Evy Bongers [mailto:lists+check-mk@evybongers.nl]
Sent: Thursday, June 29, 2017 5:10 PM
To: Aigini Navaneethan <aigini.navaneethan@apis-consulting.com>
Subject: Re: [Check_mk (english)] CheckMK does not display services for
Solaris Node
Hi Aigini,
no output.
You can make the output for the service discovery more verbose by running
cmk -vvvI --debug.
Check_MK agent?
Regards,
Evy
I am not sure if the information below will help, but when I run the
commands below, it prompts with some message :'
# inetconv
inetconv: Notice: Service manifest for 100235/1 already generated as
/var/svc/manifest/network/rpc/100235_1-rpc_ticotsord.xml, skipped
inetconv: Notice: Service manifest for check_mk already generated as
/var/svc/manifest/network/check_mk-tcp.xml, skipped
# inetconv -e
svc:/network/rpc-100235_1/rpc_ticotsord:default enabled
svc:/network/check_mk/tcp:default enabled
Could it be a concern?
From: Aigini Navaneethan [mailto:aigini.navaneethan@apis-consulting.com]
Sent: Thursday, June 29, 2017 5:18 PM
To: Evy Bongers <lists+check-mk@evybongers.nl>
Subject: RE: [Check_mk (english)] CheckMK does not display services for
Solaris Node
Hello Evy,
[root@L28falcon agents]# cmk -vvvI --debug L17pvs2a Discovering services on
L17pvs2a:
L17pvs2a:
  nothing new
1.2.6p5.
Regards,
Aigini
Solaris Node
Hi Aigini,
no output.
cmk -vvvI --debug.
Check_MK agent?
Regards,
Evy
Can you telnet from check_mk host and see output ?
$ telnet 6556
Andy
Yes, I can.
$ telnet 6556
Andy
Yes, I can.
$ telnet 6556
Andy
Hi Evy,
These are the only ones listed :
<<<solaris_multipath>>>,<<<tcp_conn_stats>>>,<<>>,<<>>,<<<zpool_status>>>,<<>>,<<>>,<<<zfs_arc_cache>>>,<<>>,<<>>.
Now I can see some services displaying on the monitoring tool, like Check_MK, Check_MK Discovery, CPU Load, Filesystem /, Filesystem /libc/libc.so.1, NTP Time, Number of threads, TCP Connections, Uptime.
Why does it not display the rest of the services?
Regards,
Aigini
On Fri, Jun 30, 2017 at 2:07 AM, Evy Bongers evy@evybongers.nl wrote:
In that case, you’ve set up check_mk agent correctly on your solaris servers.
How much output does the telnet command give you?
More specifically, wat sections does the agent list? A section is ‘<<>>’, where name can be check_mk, cpu, memory etc.
Regards, Evy
On 29 June 2017 12:38:41 CEST, Aigini Navaneethan aigini.navaneethan@apis-consulting.com wrote:
Yes, I can.
Sent: Thursday, June 29, 2017 6:16 PM
To: Aigini Navaneethan aigini.navaneethan@apis-consulting.com; checkmk-en@lists.mathias-kettner.de
Subject: Re: [Check_mk (english)] CheckMK does not display services for Solaris Node
$ telnet 6556
Andy
Sent from my Android device with K-9 Mail. Please excuse my brevity.
Hi Aigini,
Assuming that you don't have any zpools configured and don't use
multipathing, the services listed in your screenshot may very well be
all that can be checked, based on you current agent output.
Are there any specific services you would like to monitor?
Regards,
Evy
On 30/06/17 04:58, Aigini Navaneethan wrote:
Hi Evy,
<<<ntp>>>
<<<uptime>>>
<<<zpool_status>>>
<<<cpu>>>
<<<ps>>>
<<<zfs_arc_cache>>>
<<<zfsget>>>
<<<df>>>
This morning I checked from the monitoring tool, and found that some
services display, like this :
Inline image 1
Why does it not list the rest of the services?
Regards,
Aigini
On Fri, Jun 30, 2017 at 2:07 AM, Evy Bongers <evy@evybongers.nl > <mailto:evy@evybongers.nl>> wrote:
    In that case, you've set up check_mk agent correctly on your solaris
    servers.
    '<<<name>>>', where name can be check_mk, cpu, memory etc.
    Regards, Evy
    On 29 June 2017 12:38:41 CEST, Aigini Navaneethan > <aigini.navaneethan@apis-consulting.com > <mailto:aigini.navaneethan@apis-consulting.com>> wrote:
        Yes, I can.
        <mailto:andy.paton@gmail.com>]
        *Sent:* Thursday, June 29, 2017 6:16 PM
        *To:* Aigini Navaneethan <aigini.navaneethan@apis-consulting.com
        <mailto:aigini.navaneethan@apis-consulting.com>>;
        <mailto:checkmk-en@lists.mathias-kettner.de>
        *Subject:* Re: [Check_mk (english)] CheckMK does not display
        $ telnet <solaris node> 6556
        Andy
Not for now, thanks.
On 1 Jul 2017 01:42, “Evy Bongers” lists+check-mk@evybongers.nl wrote:
Hi Aigini,
Assuming that you don’t have any zpools configured and don’t use
Regards,
Evy
Hi Evy,
<<<zpool_status>>>
<<<zfs_arc_cache>>>
Inline image 1
Regards,
Aigini
servers.
Regards, Evy
    Yes, I can.
    Andy
I believe if you install libstatgrab you may get some additional information (disk, cpu, ram, possibly network IIRC).
From: checkmk-en checkmk-en-bounces@lists.mathias-kettner.de on behalf of Aigini Navaneethan aigini.navaneethan@apis-consulting.com
Date: Saturday, 1 July 2017 at 03:46
To: Evy Bongers lists+check-mk@evybongers.nl
Cc:checkmk-en@lists.mathias-kettner.decheckmk-en@lists.mathias-kettner.de
Hi Aigini,
Regards,
Evy
Hi Evy,
<<<zpool_status>>>
<<<zfs_arc_cache>>>
Inline image 1
Regards,
Aigini
servers.
Regards, Evy
    Yes, I can.
    Andy
