[Check_mk (english)] Cisco Meraki polling
​Hello,
I would like to monitor some Cisco Meraki equipment, however I am unable to add the devices using the auto discovery option as the equipment is monitored via the Meraki dashboard on a non standard port number. Has anyone found a way to implement monitoring
for these devices?
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T: 0151 423 3633
**D: **0151 423 9329
E: msmith@mlrnetworks.co.uk
This email has been scanned for email related threats and delivered safely by Mimecast.
For more information please visit http://www.mimecast.com
Hi Matthew,
if the devices only use other port numbers for SNMP then it should be possible to use the “UDP port used for SNMP” setting to point to the right port for this devices.
I took a look at the Meraki documentation and they are using normal standard SNMP without different port settings.
The documentation only says to setup a whitelist for communication from outside the Meraki network.
Best regards
Andreas
Matthew Smith msmith@mlrnetworks.co.uk schrieb am Mo., 13. März 2017 um 11:42 Uhr:
​Hello,
for these devices?
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T: 0151 423 3633
checkmk-en mailing list
​Hi,
Thank you for the quick reply,
I have added a rule to poll via port 16100 which is the SNMP port associated with our dashboard however the auto-discovery process in Check MK only discovered two services, one reporting the uptime of the cloud controller and the current status and software
version of the cloud controller. The AP’s are not discovered.
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T: 0151 423 3633
Sent: Monday, March 13, 2017 11:37 AM
To: Matthew Smith; checkmk-en@lists.mathias-kettner.de
Subject: Re: [Check_mk (english)] Cisco Meraki polling
Hi Matthew,
Best regards
Andreas
​Hello,
implement monitoring for these devices?
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T: 0151 423 3633
if you take a look at the link https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/SNMP_Overview_and_Configuration
Inside you find this
Polling from Outside the Network
By default, Meraki devices cannot be polled from outside the network. However, after setting up the community string, an MX can be configured to allow polling from a remote IP whitelist, configured under Organization > Configure > Settings > SNMP.
If this don’t work for your setup it is possible that you need a monitoring satellite inside the Meraki network. I’m no Meraki specialist so i don’t know what you need to do there.
Best regards
Andreas
Matthew Smith msmith@mlrnetworks.co.uk schrieb am Mo., 13. März 2017 um 15:33 Uhr:
​Hi,
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T: 0151 423 3633
Hi Matthew,
Best regards
Andreas
​Hello,
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T: 0151 423 3633
Hi Matthew,
I have inherited some meraki monitoring, for aircard status and other things, It is running in a Nagios (without CMK) so is doing some things via passive checks. We query the portal at snmp.meraki.com:16100 and pull back various stats. l I’d like to query the devices independently as is traditional with network gear, but haven’t looked into it too much. I will be implementing it as a plugin for CMK at some point, but in the meantime I can share the script with you if you’d like.
Paul
On Mon, Mar 13, 2017 at 7:42 AM, Andreas Döhler andreas.doehler@gmail.com wrote:
Best regards
Andreas
​Hi,
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T: 0151 423 3633
Hi Matthew,
Best regards
Andreas
​Hello,
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T: 0151 423 3633
That would be greatly appreciated if you can share the script with me.
Thanks,
Matt Smith.
Sent from my iPhone
On 21 Mar 2017, at 05:38, Paul D paulmonitoring@gmail.com wrote:
Hi Matthew,
Paul
Best regards
Andreas
​Hi,
and the current status and software version of the cloud controller. The AP’s are not discovered.
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T :
0151 423 3633
**D: ** 0151
423 9329
To: Matthew Smith;
Hi Matthew,
Best regards
Andreas
​Hello,
anyone found a way to implement monitoring for these devices?
Thanks,
Matthew Smith
Technical Architect
MLR Networks Ltd
T :
0151 423 3633
**D: ** 0151
423 9329
