[Check_mk (english)] cmk plugin for ceph mimic broken
Hi all,
unfortunately I boasted CMK to be able to handle ceph natively with 1.5 while talking to one of our storage guys.
Now, we are using Mimic (version 13.X) of ceph and they changed the output of "ceph df" in Mimic...:frowning:
Now, (at least) the df check is broken. Has anyone already fixed that (before I start patching the code)?
Officially I suggest using the json-option of ceph df like mentioned here:
But this means patching the agent AND the check code.
Any thoughts?
Best regards
Maik
Hi all,
I felt like fixing the issue myself. If you are in need of tests working with Mimic, (ab)use the files linked here:
https://hessenbox.uni-kassel.de/dl/fiRoyzHX3vriWmEWzCmask4G/ceph_new.zip
They should work with older versions of ceph, too, but I wasn't able to test it.
Best regards
Maik
Am 30.10.2018 um 10:11 schrieb Dr. Maik Götte:
Hi all,
output of 'ceph df' seems to be changed in mimic-Release · Issue #42 · ceph/ceph-nagios-plugins · GitHub
Any thoughts?
Best regards
Maik
checkmk-en mailing list
Our extension for monitoring Ceph uses the JSON output of the ceph
commands and works with Mimic:
https://github.com/HeinleinSupport/check_mk/tree/master/ceph
I do not know why the Check_MK team started to develop their own Ceph
checks…
Regards
Am 30.10.18 um 10:11 schrieb Dr. Maik Götte:
Robert Sander
Heinlein Support GmbH
Tel: 030 / 405051-43
Fax: 030 / 405051-19
Zwangsangaben lt. §35a GmbHG:
HRB 93818 B / Amtsgericht Berlin-Charlottenburg,
Geschäftsführer: Peer Heinlein -- Sitz: Berlin
Dr. Maik Götte maik.goette at uni-kassel.de
wrote on Tue Oct 30 16:22:35 CET 2018
That fixes ceph_df with Check_MK 1.5.0p11 Raw for me.
Thank you.
pcfe
------------------------ http://www.pcfe.net/ ------------------------
     Patrick C. F. Ernzer | e-mail: pcfe@pcfe.net
--go-and-make-your-own-disclaimer--+----------------------------------
"Could you fax over a copy?"
"No, I can't fax because of where I live"
"Where do you live?"
"The 21st century"
                          -- @mc_hankins
