Summary: What's the difference between
cmk -II
and
cmk --inventory?
Details follow:
We have enough churn in our environment to make it worthwhile to run a
weekly cron job to regenerate our entire service inventory.
This runs a shell script under the site account, with contents that boil
down to the following:
~/bin/cmk -II
~/bin/cmk -R
A few weeks ago we upgraded from an omd-based installation of check_mk
version 1.2.4p5 to the enterprise edition of 1.2.8p5. With that, the
reinventory script continued to run, but it stopped listing the errors
it found during the -II operation.
Typical output before the change would look something like this (with
actual hostnames and IP addresses elided):
Failed to inventorize <hostname1>: Cannot get data from TCP port NNN.NNN.NNN.XXX:6556: timed out
Failed to inventorize <hostname2>: Cannot get data from TCP port NNN.NNN.NNN.YYY:6556: timed out
Failed to inventorize <hostname3>: Cannot get data from TCP port NNN.NNN.NNN.ZZZ:6556: [Errno 111] Connection refused
This information is useful, because it helps our operations staff track
down the underlying problems with unreachable hosts.
Since I didn't want to lose it, I looked around and found the --inventory
option. This appeared to do the same job as -II, and continued to produce
exactly the same report we were accustomed to seeing.
I thought all was well, until last week I defined a couple of clusters and
added rules to distinguish the cluster-level services from the node-level
services. Initially that worked exactly as expected, but yesterday I found
that the cluster hostnames had reverted to having the node-level services
associated with them.
Eventually I realized that doing the inventory with --inventory was causing
that problem, and that the solution was to revert to -II instead.
...but I'd really like to get my report back. Can anyone explain what the
real difference is between the two inventory methods, and whether there's
a way to do what I want?
(And is this stuff is documented anywhere? I did look before asking these
questions here, but all I could find was the same discussion of -I and -II
which I first saw two years ago; I couldn't find anything at all about the
--inventory option, or about the change in -II behaviour.)
Thanks,
- Steven
___________________________________________________________________________
Steven Winikoff | "You can leave in a taxi. If you can't
Concordia University | get a taxi, you can leave in a huff.
Montreal, QC, Canada | If that's too soon, you can leave in a
Steven.Winikoff@concordia.ca | minute and a huff."
> - Groucho Marx
