[Check_mk (english)] "Critical" instead of "Unknown"
Hello.
I need check_mk to return “Critical” instead of “Unknown” in case of timeout. Any hint ?
Rdgs.
Paulo Azevedo
PTisp - Wherever internet can take you…
pazevedo@ptisp.pt
tel : +351 249 739 099 | fax. +351 249 739 154
www.ptisp.pt
inside WATO you find the rule “Status of Check_MK service” there you can define how it will behave in case of a problem
br
Andreas
2014-03-12 23:44 GMT+01:00 Paulo Azevedo pazevedo@ptisp.pt:
Hello.
Rdgs.
Paulo Azevedo
pazevedo@ptisp.pt
www.ptisp.pt
checkmk-en mailing list
You can find the option here - Host & Service Parameters → Access to Agents → Status of the Check_MK Service
br
Andreas
2014-03-13 19:06 GMT+01:00 Paulo Azevedo pazevedo@ptisp.pt:
I’m sorry, Andreas, where exactly ? Can’t find the option in WATO…
Paulo Azevedo
pazevedo@ptisp.pt
www.ptisp.pt
To: “Paulo Azevedo” pazevedo@ptisp.pt
Sent: Thursday, March 13, 2014 3:50:04 PM
Subject: Re: [Check_mk (english)] “Critical” instead of “Unknown”
br
Andreas
Hello.
Rdgs.
Paulo Azevedo
pazevedo@ptisp.pt
www.ptisp.pt
Ok, got it … But the problem is when check_mk doesn’t even return a response (because it times out) and that’s not covered .
The thing is… If I have a host that “freezes” (overload, OOM, whatever) but still respond to icmp requests, the only clue that it is hung is the check_mk becoming “unknown” due to timeout, so I need it to be “critical”.
If it was a plugin/check, it’d be easy to change the behaviour (by tricking it to return 2 instead of 3), but I’m not able to find a way to do it with check_mk.
Any hints ?
Regards,
Paulo
br
Andreas
Paulo Azevedo
pazevedo@ptisp.pt
tel : +351 249 739 099 tel:%2B351%20249%20739%20099 | fax. +351 249 739 154 tel:%2B351%20249%20739%20154
www.ptisp.pt <http://www.ptisp.pt>
br
Andreas
Hello.
Rdgs.
Paulo Azevedo
pazevedo@ptisp.pt
