Hi Nico,
you need to uninstall the current version of check_mk_raw.
Before you can uninstall the current existing sites need to be stopped.
Then you have to remove the symlink inside the site directory to version
root@omd1:/omd/sites/test2# ls -l
total 16
lrwxrwxrwx 1 test2 test2 11 Nov 9 2016 bin → version/bin
drwxr-xr-x 19 test2 test2 4096 Dec 9 2016 etc
lrwxrwxrwx 1 test2 test2 15 Nov 9 2016 include → version/include
lrwxrwxrwx 1 test2 test2 11 Nov 9 2016 lib → version/lib
drwxr-xr-x 5 test2 test2 4096 Nov 9 2016 local
lrwxrwxrwx 1 test2 test2 13 Nov 9 2016 share → version/share
drwxr-xr-x 12 test2 test2 280 Nov 6 08:50 tmp
drwxr-xr-x 14 test2 test2 4096 Oct 16 08:23 var
lrwxrwxrwx 1 test2 test2 27 Oct 16 08:23 version → …/…/versions/1.4.0p15.cre
Only remove the “version” link.
Now you can uninstall the check_mk_raw version.
Do the upgrade procedure. Install the same check_mk_raw version as the old one for your new distribution.
Recreate the symlink.
Start the site.
All should work as before. It could be that the Apache configuration must be altered.
If you use the latest check_mk_raw version this should not be needed.
br
Andreas
Nico ndebrou@gmail.com schrieb am Mo., 6. Nov. 2017 um 11:35 Uhr:
I would like to upgrade from debian 8 to debian 9. How i can do ?
Apt-get doesn’t work because the installation of check_mk_raw is installed with dpkg (so no dependencies enable…)
I don’t found anything on the website.
Thanks,
Nico
Garanti sans virus. www.avast.com
checkmk-en mailing list
