I have installed checkmk 1.5.0p11.cre and I have been trying to configurate the Distributed Monitoring, I followed this tutorial https://checkmk.com/cms_distributed_monitoring.html but at the end I can not see the host in the master site, only in slave site.
Someone has been the same problem?
Marvin Giron
Yes. I’m also facing similar problem with monitoring tool. It is showing some permission error. After resolving that issue It is opening check_mk page. But I’m unable to login to check_mk.
Marvin Giron
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
Without seeing the configuration it is difficult to say, may be you need to set the "Status host" as your master site and the "monitoring site" as your slave.
Marvin Giron
checkmk-en@lists.mathias-kettner.dehttps://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
-- Beste Grüße
Ghassan Elrayah
Mail:
ghassan.elrayah@live.de
the slave should be also added as a host to the master as well
Marvin Giron
-- Beste Grüße
Ghassan Elrayah
Mail:
-- Beste Grüße
Ghassan Elrayah
Mail:
Hi Marvin,
Inside your WATO “Distributed Monitoring” configuration you should see two sites. One your local site with the settings “Connection” → “Connect to local site” and your slave site with a TCP setting for the connection.
Is this right?
If yes - what happens if you temporary disable the slave site connection?
Best regards
Andreas
PS: new location for all CheckMK questions and requests - https://forum.checkmk.com
Am Mi., 4. Dez. 2019 um 10:22 Uhr schrieb Ghassan Elrayah ghassan.elrayah@live.de:
Marvin Giron
[https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en](https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en)
-- Beste Grüße
Ghassan Elrayah
Mail: ghassan.elrayah@live.de
-- Beste Grüße
Ghassan Elrayah
