[Check_mk (english)] Distributed WATO - Replication Status not completing. Slave configs out of sync
Hi.
We had this problem with one specific slave with a large configuration.
We fixed it with the solution mentioned here:
http://hermannsspace.de/wp/reverse-proxy-timeouts-with-check_mk/
Basically, we modify the /omd/sites/your_slave_site /etc/apache/proxy-port.conf and change the line that
contains the directive ProxyPass from:
ProxyPass http://127.0.0.1:5000/**your_slave_site** retry=0 disablereuse=On
to:
 retry=0 disablereuse=On **acquire=10000 timeout=600 Keepalive=On ttl=120 connectiontimeout=10**
Once modified, we restart everything and it works.
Hope this can help.
</details>
A great idea as well. Thank you.
I’ll report back how it goes.
On Mon, Mar 21, 2016 at 10:03 AM, Beaulieu, René [2] Beaulieu.Rene2@hydro.qc.ca wrote:
Hi.
ProxyPass [http://127.0.0.1:5000/](http://127.0.0.1:5000/)**your_slave_site** retry=0 disablereuse=On
to:
ProxyPass http://127.0.0.1:5000/your_slave_site
retry=0 disablereuse=On acquire=10000 timeout=600 Keepalive=On ttl=120 connectiontimeout=10
Hope this can help.
checkmk-en mailing list
I was able to duplicate the symptom on my master server. One of the
slaves takes about 40 seconds
to complete. On the master I changed /etc/httpd/conf/httpd.conf
Timeout 45
to:
Timeout 30
and restarted httpd. Triggered an 'Apply Configuration' and the
slower site never showed up as done
on the master…it actually did finish, but the webpage didn’t show
it.
Then I changed it to:
Timeout 60
and restarted httpd. It's working again.
On 03/21/2016 11:09 AM, Joe Hedrick
wrote:
A great idea as well.� Thank you. �
Beaulieu, Ren� [2] <>
wrote:
Hi.
                We had this
configuration.
                We fixed it with
                Basically, we
and change the line that contains the
directive�ProxyPass from:
to:
                  ProxyPass
retry=0 disablereuse=On ** acquire=10000
                Once modified,
                Hope this can
help.
Beaulieu.Rene2@hydro.qc.cacheckmk-en@lists.mathias-kettner.dehttp://lists.mathias-kettner.de/mailman/listinfo/checkmk-en
Bumping my timeout from 60 to 120 looks to have allowed enough time for a successful sync. That seems like quite a long time though. I think some further investigation as to what is taking so long in syncs is in order.
Thank you all for your help.
Timeout 45
to:
Timeout 30
on the master...it actually did finish, but the webpage didn't show
it.
Timeout 60
wrote:
Hi.
                We had this
configuration.
                We fixed it with
                Basically, we
to:
                  ProxyPass
                Once modified,
                Hope this can
help.
