[Check_mk (english)] Dns cache not updating with system's one?
Hi there,
I am running an Ubuntu 18.04.1 VM with Raw 1.4.0p33.
A host moved to another subnet and it’s DNS was updated on the DNS
server on the domain.
After short time, as expected, from the VM’s console I could resolve the
host correctly.
Check MK wouldn’t update the host though. I managed to “force” it by
renaming the host in WATO and naming it back to the correct name.
Any idea why and how to fix it for the future?
Best
David
Check_MK uses its own DNS cache to not have to resolve a name every time a check runs.
This cache gets updated every 24 hours.
You can manually update the cache with the "Update DNS Cache" button in the host properties in WATO.
Regards
On 13.11.18 17:24, David Schmidt wrote:
Check MK wouldn't update the host though. I managed to "force" it by
Robert Sander
Heinlein Support GmbH
Tel: 030 / 405051-43
Fax: 030 / 405051-19
Amtsgericht Berlin-Charlottenburg - HRB 93818 B
Geschäftsführer: Peer Heinlein - Sitz: Berlin
Wow, that is a quick reply, thanks a lot!
On Tue, Nov 13, 2018, 17:46 Robert Sander <r.sander@heinlein-support.de wrote:
You can manually update the cache with the “Update DNS Cache” button in the host properties in WATO.
Regards
Robert Sander
https://www.heinlein-support.de
checkmk-en mailing list
Second Option is that you use the DNS name inside the “IP” field inside your host definition.
Then Check_MK resolves the name every time it makes contact to this host.
Good for devices with DHCP addresses.
Best regards
Andreas
Am Di., 13. Nov. 2018 um 17:50 Uhr schrieb David Schmidt schmidt.david.j.m@gmail.com:
Regards
Robert Sander
Thanks for the tip!
Best regards
Andreas
Regards
Robert Sander
