[Check_mk (english)] Domain Login
Hi all,
Is there a way to allow users to login in to the check_mk GUI via their domain username and password instead of creating profiles with htpasswd?
Thanks,
Dino
To read FirstRand Bank’s Disclaimer for this email click on the following address or copy into your Internet browser:
https://www.fnb.co.za/disclaimer.html
If you are unable to access the Disclaimer, send a blank e-mail to firstrandbankdisclaimer@fnb.co.za
and we will send you a copy of the Disclaimer.
You can use the modules in apache for authentication against ldap or kerberos
http://support.microsoft.com/kb/555092
http://www.held-im-ruhestand.de/software/apache-ldap-active-directory-authentication
On Tue, Sep 13, 2011 at 7:41 AM, Charalambous, Dino DCharalambous@fnb.co.za wrote:
Hi all,
Thanks,
Dino
checkmk-en mailing list
If you use WIndows 2008 R2, is Kerberos a very good idea.
We use Kerberos for the authentication. In our case via Single Sign-On and works fine!
Von: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de] Im Auftrag von Ewold
Gesendet: Dienstag, 13. September 2011 10:47
An: Charalambous, Dino
Betreff: Re: [Check_mk (english)] Domain Login
Hi all,
Thanks,
Dino
If you are unable to access the Disclaimer, send a blank e-mail to firstrandbankdisclaimer@fnb.co.za and we will send you a copy of the Disclaimer.
Think green - keep it on the screen.
This e-mail and any attachment is for authorised use by the intended recipient(s) only. It may contain proprietary material, confidential information and/or be subject to legal privilege. It should not be copied, disclosed to, retained or used by, any other party. If you are not an intended recipient then please promptly delete this e-mail and any attachment and all copies and inform the sender. Thank you.
