I’ve got 6 extension packages installed on my CheckMK instance and they all work fine.
I’ve noticed it takes over 60 seconds for my ‘Extension Packages’ page to actually load – sometimes Python returns an error saying execution took too long. Today I span up a test instance, added all 6 packages and the page loads within 5 seconds as expected on the test box.
So I am wondering if there is a cache, or some files being read which shouldn’t be. Can anyone advise where I might want to start looking?
There are no other issues I am experiencing, just very slow loading of this one specific page. I am using 1.6.0p6.
the problem must not be one of the packages. If you have some other modified or own files inside your ~/local structure then these files are browsed at the load time of the extension page.
If i remember correctly these files are also checked for correct syntax and so on with version 1.6 and upwards.
the code generating the extension packages page has a runtime of O(n³)
or similar. I have straced the call and seen more than 7.000 read
requests for the 30 installed packages.
There is room for optimization…
The developers have been notified.
Regards
Robert Sander
Heinlein Support GmbH
