Getting UP -> DOWN alert even when server is up. Could you please help how to fix this issue.
Thanks,
Venkataramu Thammanna
Thanks,
You could change your network settings from to ‘Local network (low
latency)’ to ‘WAN (high latency)’
I’ve got a host tag for that: Networking Segment
and a rule in the Main directory that sets the host check thresholds
for those hosts. (basically all of mine
since we have another system that does ping checks and I don’t want
duplicate notifications from check_mk
and the other monitoring server.
On 09/08/2015 10:17 AM, Thammanna,
Venkataramu wrote:
Getting UP →
Thanks,
VenkataramuThammanna
do not agree_______________________________________________ checkmk-en mailing list We�ll meet in Munich for the 2nd Check_MK Conference! Book your place now and be part of it. October 18th-20th, 2015
checkmk-en@lists.mathias-kettner.dehttp://lists.mathias-kettner.de/mailman/listinfo/checkmk-enhttp://mathias-kettner.com/conference
It is on WAN only. Still alert getting.
Thanks,
Team Lead – Offshore IT support
O: +91 804 084 7777
C: +91 8095551757
A member of the GalaxE Group
Sent: Tuesday, September 08, 2015 8:35 PM
To: Thammanna, Venkataramu; checkmk-en@lists.mathias-kettner.de
Subject: Re: [Check_mk (english)] Getting UP → DOWN alert even when server is up. Please help how to fix this issue.
You could change your network settings from to ‘Local network (low latency)’ to ‘WAN (high latency)’
and a rule in the Main directory that sets the host check thresholds for those hosts. (basically all of mine
since we have another system that does ping checks and I don’t want duplicate notifications from check_mk
On 09/08/2015 10:17 AM, Thammanna, Venkataramu wrote:
Getting UP → DOWN alert even when server is up. Could you please help how to fix this issue.
Thanks,
do not agree
We’ll meet in Munich for the 2nd Check_MK Conference!
[http://mathias-kettner.com/conference](http://mathias-kettner.com/conference)
I am sorry to ask this queries in this mail.
How to change the Alert thresholds on the Memory utilization to Warning @ 80%, and critical @ 95%
Getting error while view in graphs “**Alert: **You are not authorized to view this host/service ”.
I don’t have any issue with omdadmin account but with different account which is added to administrator group.
Thanks,
O: +91 804 084 7777
C: +91 8095551757
Sent: Tuesday, September 08, 2015 8:37 PM
To: ‘Jam Mulch’; checkmk-en@lists.mathias-kettner.de
Subject: RE: [Check_mk (english)] Getting UP → DOWN alert even when server is up. Please help how to fix this issue.
Thanks,
O: +91 804 084 7777
C: +91 8095551757
Thanks,
do not agree
The default check sends 5 pings. If they fail, CMK will think the host is down. The best way to fix this is to increase the number of checks before the host is marked as down. If you set it to 3, then the system will have to fail to respond to 5 pings 3 times in a row before it will alert.
In WATO, look under Host & Service Parameters
-> Monitoring Configuration -> Maximum number of check attempts for host.
to fix this issue.
There could be other factors. Look at why the host is considered down.
Was it dropped packets? High Round Trip Average (RTA)? Timeout? Errors?
You can relax the thresholds to accommodate your 'normal' performance
on your network.
Rule: PING and host check parameters
to fix this issue.The default check sends 5 pings. If they fail, CMK will think the host is down. The best way to fix this is to increase the number of checks before the host is marked as down. If you set it to 3, then the system will have to fail to respond to 5 pings 3 times in a row before it will alert.
http://lists.mathias-kettner.de/mailman/listinfo/checkmk-enWell meet in Munich for the 2nd Check_MK Conference!
Jam Mulch,
There is no packets drops , timeout and errors. Everything is normal.
Thanks,
Team Lead - Offshore IT support
O: +91 804 084 7777
C: +91 8095551757
vthammanna@galaxe.com
-----Original Message-----
Sent: Tuesday, September 08, 2015 11:50 PM
To: Sketch; Thammanna, Venkataramu
Subject: Re: [Check_mk (english)] Getting UP -> DOWN alert even when server is up. Please help how to fix this issue.
You can relax the thresholds to accommodate your 'normal' performance on your network.
help how to fix this issue.The default check sends 5 pings. If they fail, CMK will think the
before it will alert.In WATO, look under Host & Service Parameters
The information transmitted in this email is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient(s) is prohibited. If you received this transmission in error, please contact the sender by reply e-mail or by telephone at 732-868-0400. Also, please delete and destroy all copies of this email and its contents, including all copies stored in the recipient's computer, printed or saved to disk.
