[Check_mk (english)] [GRAPH AXIS] Mb in 1.6
I would like to request some informations about graphs axis on the Raw 1.6.0p3 version.
I use the check_mk-if64 fonction to graph some Cisco ASA ports.
With the older 1.5 version I used in WATO the "Host & Services Parameters / Network interfaces ans switch ports" Rules to change the measurement unit from MB to Mb.
Now, in 1.6.0p3 version graph axis are not showing Mb anymore, Service is OK (exemple for one port: 1 Gbit/s, In: 15.04 Mbit/s (1.5%), Out: 4.52 Mbit/s (0.5%))
But graph axis are showing strange value: 2.6905 M Last 32.0791 M Max 2.2987M Average
Do I miss something in the last version to continue showing graph axis in Mb/s ?
Thanks for your help.
Valéry Lang
Hi Valéry,
I think this problem lies in the PNP template for the graph.
In version 1.6 this template is not static anymore like before.
You can compare this links https://github.com/tribe29/checkmk/tree/1.6.0/pnp-templates and https://github.com/tribe29/checkmk/tree/1.5.0/pnp-templates
If you take the old template from 1.5 your graph should be the same as before.
check_mk-if64.php
Best regards
Andreas
Am Di., 8. Okt. 2019 um 09:34 Uhr schrieb Valéry Lang valery.lang@mines-paristech.fr:
With the older 1.5 version I used in WATO the “Host & Services Parameters / Network interfaces ans switch ports” Rules to change the measurement unit from MB to Mb.
Valéry Lang
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
Yes, that’s what I did and it works but I would like to know where the new parameters could be changed if they are not static anymore as I don’t want to use files from an earlier version who can be “broken” in futur upgrades ?
Thanks Andreas
Valéry Lang
De: “Andreas Döhler” andreas.doehler@gmail.com
À: “Valéry Lang” valery.lang@mines-paristech.fr
Cc: “checkmk-en” checkmk-en@lists.mathias-kettner.de
Envoyé: Mardi 8 Octobre 2019 22:11:20
Objet: Re: [Check_mk (english)] [GRAPH AXIS] Mb in 1.6
Hi Valéry,
check_mk-if64.php
Best regards
Andreas
Valéry Lang
