we have noticed that when check_mk inventory is run, or when doing discovery from WATO, the discovery eventually times out.
However, if we get the discovery to go through, monitoring actually works fine.
Anyway, it seems that the problem is caused by SNMP bulkwalks against certain systems (such as Cisco CUCM). They don't seem to like "open-ended" bulkwalks where you probe every OID in existence. However, setting the host to legacy snmpv1 mode allows discovery to be conducted.
However, during actual monitoring (when you know which OIDs you are polling, and not every check in existence), bulkwalks work just fine.
Is there any way to have CMK not use bulkwalks for discovery, but use them during monitoring?
Thanks.
- Dr. Antti Mäkelä | Senior Architect | CCIE #20962 -
- Vintor Oy, Itsehallintokuja 6, 02600 Espoo | www.vintor.fi -
Thanks.
Problem is that to my understanding this approach also changes the monitoring to use "nobulk". I just need the discovery/Check_MK Inventory service to use the "nobulk"...
________________________________________
From: Stier, Matthew <Matthew.Stier@us.fujitsu.com>
Sent: Tuesday, June 21, 2016 18:07
To: Mäkelä, Antti; checkmk-en@lists.mathias-kettner.de
Subject: RE: Having *inventory* use snmpwalk, but conduct actual monitoring with bulkwalks
Use the 'nobulk' tag to force Check_MK to use 'snmpwalk' instead of 'snmpbulkwalk' on the hosts you assign it to.
Thanks.
Problem is that to my understanding this approach also changes the monitoring to use “nobulk”. I just need the discovery/Check_MK Inventory service to use the “nobulk”…
Subject: [Check_mk (english)] Having inventory use snmpwalk, but conduct actual monitoring with bulkwalks
Anyway, it seems that the problem is caused by SNMP bulkwalks against certain systems (such as Cisco CUCM). They don’t seem to like “open-ended” bulkwalks where you probe every OID in existence. However, setting the host to legacy snmpv1 mode allows discovery to be conducted.
Thanks.
Ok, well, if that’s not possible then we’ll just have to live with it.
I’ve found a related issue where it seems that I cannot turn off bulkwalk for SNMPv3. Setting “nobulk” works if using SNMPv1/SNMPv2c, but looks
like SNMPv3 is stuck with bulkwalk (at least according to cmk –vvvvvvv –debug –I). Oh well, for most part the enhanced security of SNMPv3 is not strictly necessary in our environment.
www.vintor.fi -
to be conducted.
Thanks.
www.vintor.fi -
From: Marcel Schulte [mailto:schulte.marcel@gmail.com] Sent: 21. kesäkuuta 2016 18:17 To: Mäkelä, Antti; Stier, Matthew; checkmk-en@lists.mathias-kettner.de Subject: Re: [Check_mk (english)] Having inventory use snmpwalk, but conduct actual monitoring with bulkwalks
Hi Antti,
it’s impossible to use different features for discovery and checks. You have to use bulk or nobulk for both of them.
If bulk raised issues I’d use nobulk as fixed configuration for affected hosts.
www.vintor.fi -
to be conducted.
Thanks.
www.vintor.fi -
Granted, I didn’t use tags directly in config file, but I set the ”don’t use bulk” via WATO. Basically, I set “Hosts using SNMP bulk walk (enforces
SNMP v2c)” to NOT include my target hosts. Is there a separate place to disable bulkwalk for SNMPv3?
Setting “nobulk” works if using SNMPv1/SNMPv2c, but looks like SNMPv3 is stuck with bulkwalk (at least according to cmk –vvvvvvv –debug –I). Oh well, for most part the enhanced security of SNMPv3 is not strictly necessary in our environment.
Hi Antti,
www.vintor.fi -
to be conducted.
Thanks.
www.vintor.fi -
