[Check_mk (english)] help with nrpe
Having an issue with nrpe and check_mk. I need to use nrpe for the time being while we switch over all the servers to the agent.
Can someone give me a quick rundown on a sample host on how to enable this to work.
I can run
/omd/sites/testsite/lib/nagios/plugins/check_nrpe -H amat1 -c check_load
OK - load average: 0.00, 0.00, 0.00|load1=0.000;15.000;30.000;0; load5=0.000;10.000;25.000;0; load15=0.000;5.000;20.000;0;
But when I add
define service{
use generic-service
host_name testsite
service_description CPU15
check_command check_nrpe!check_load
define command{
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$
CHECK_NRPE: Error - Could not complete SSL handshake.
What am I doing wrong?
H E A R S T Enterprise Technology
Shared Services – Data Center
Alan Todd** **l 214 N. Tryon Street
l Charlotte, NC 28202 l Phone: 704-348-0018
l
You define check_nrpe, but you call check_load in your service definition. Change one to match the other.
–Doug
I can run
But when I add
define service{
use generic-service
host_name testsite
define command{
l
This e-mail message is intended only for the personal use of the recipient(s) named above. If you are not an intended recipient, you may not review, copy or distribute this message. If you have received this communication in error, please notify the Hearst Service Center (cadmin@hearstsc.com) immediately by email and delete the original message.
checkmk-en mailing list
Well how do I check_users and load and other stuff then
l
–Doug
I can run
But when I add
define service{
use generic-service
host_name testsite
define command{
Alan Todd ** **l 214 N. Tryon Street
l
Ah, I’m sorry. I misread your definition.
The only difference I see is that your hostname is amat1 on the command line, and it is testsite in the nagios config. Can you ping it by the same hostname (testsite)? If you enable debugging on nrpe (on the machine being checked), does it show any additional useful information?
–Doug
l
Sent: Monday, March 24, 2014 1:56 PM
To: ATodd
Subject: Re: [Check_mk (english)] help with nrpe
–Doug
I can run
But when I add
define service{
use generic-service
host_name testsite
define command{
l
Well to be honest they are both amat1, had it as testsite for anonymity LOL . as you see how that worked out.
l
–Doug
l
To: ATodd
–Doug
I can run
But when I add
define service{
use generic-service
host_name testsite
define command{
l
Figured it out…
So one small question. I am adding these into the check_mk_objects.cfg. Is there a template or file I can add things into so it won’t overwrite when I activate
changes.
Like I have 44 hosts and I pretty much have the same checks for them all. Can I add something like
Server
Router
In the agent type so it will have default checks.
l
–Doug
l
To: ATodd
–Doug
I can run
But when I add
define service{
use generic-service
host_name testsite
define command{
l
If you want to do this in an template way you can work with “host tags” to assign the definitions to your hosts.
One thing before i can describe anything - do you work with WATO or is all your config done in textfiles?
br
Andreas
2014-03-24 20:58 GMT+01:00 ATodd ATodd@hearstsc.com:
Figured it out…
changes.
Server
Router
l
Sent: Monday, March 24, 2014 2:06 PM
To: ATodd
–Doug
l
To: ATodd
–Doug
I can run
But when I add
define service{
use generic-service
host_name testsite
define command{
l
wato
l
br
Andreas
Figured it out…
I can add things into so it won’t overwrite when I activate changes.
Server
Router
l
To: ATodd
–Doug
l
To: ATodd
–Doug
I can run
But when I add
define service{
use generic-service
host_name testsite
define command{
l
Then you can go over define “active checks” → “classical active and passive nagios checks” here you define your check as you had done already above.
And there you can also define conditions when this check should be applied to the host object.
br
Andreas
2014-03-25 20:08 GMT+01:00 ATodd ATodd@hearstsc.com:
wato
l
From: Andreas Döhler [mailto:andreas.doehler@gmail.com]
Sent: Tuesday, March 25, 2014 2:55 PM
To: ATodd
Cc: Doug Clements; checkmk-en@lists.mathias-kettner.de
br
Andreas
Figured it out…
Server
Router
l
To: ATodd
–Doug
l
To: ATodd
–Doug
I can run
But when I add
define service{
use generic-service
host_name testsite
define command{
l
thanks
l
br
Andreas
wato
l
To: ATodd
Cc: Doug Clements;
br
Andreas
Figured it out…
Server
Router
l
To: ATodd
–Doug
l
To: ATodd
–Doug
I can run
But when I add
define service{
use generic-service
host_name testsite
define command{
l
