Friends,
Do we have option for host dependencies in check MK like service dependencies?
https://mathias-kettner.com/checkmk_service_dependencies.html
Regards,
Suresh
Friends,
Regards,
Suresh
https://mathias-kettner.com/cms_monitoring_basics.html#Parents
Ralf
Am 11.09.2018 um 07:00 schrieb suresh babu sureshbabusuresh661@gmail.com:
Friends,
Regards,
Suresh
checkmk-en mailing list
Hi Suresh,
You can use the parent child relations between hosts to achieve what you want.
These relations can be defined inside WATO for every host or for whole folders.
Best regards
Andreas
suresh babu sureshbabusuresh661@gmail.com schrieb am Di., 11. Sep. 2018, 07:01:
Friends,
Regards,
Suresh
Andreas,
My scenario is, check MK should not send email notification when parent host is reachable and any child host failed.
example:
host A is parent and host B and C are child.
when host C is not reachable and host A is reachable then email notification should not trigger.
Regards,
Suresh
On Tue, 11 Sep 2018 at 16:20, Andreas Döhler andreas.doehler@gmail.com wrote:
Hi Suresh,
Best regards
Andreas
Friends,
Regards,
Suresh
Well, you can do it with your notifications then. B and C would go into UNKNOWN status or abbreviated as UNKN. Just don’t setup alerts for UNKN and you won’t get them.
Get Outlook for iOS
On Tue, Sep 11, 2018 at 10:59 PM -0500, “suresh babu” sureshbabusuresh661@gmail.com wrote:
Andreas,
example:
Regards,
Suresh
Hi Suresh,
Best regards
Andreas
Friends,
Regards,
Suresh
