[Check_mk (english)] Host view, preview graphs
I am not sure if this has been raised as an issue, or if it’s a genuine one, but this appears to have broken on 3 of the instances I manage.
When looking at the “All Hosts” view, there used to be a graph icon like seen below, but when I hover over it, no graph is displayed.
Now on a new install I have this below with no graph icon.
Any ideas on how I would get this back? I can’t see anything relevant on the Edit View page.
TIA for any input.
Kind regards,
James Poore
Infrastructure Operations Professional
**Plusnet Technology **
** **Skype: 0331 654 9012****Tel:
07483 300 413
Email:
jpoore@plus.net
This email contains Plusnet information, which may be privileged or confidential.
It’s meant only for the individual(s) or entity named above. If you’re not the intended recipient, note that disclosing, copying, distributing or using this information is prohibited.
If you’ve received this email in error, please let me know immediately on the email address above. Thank you.
We monitor our email system, and may record your emails.
Plusnet plc
Registered office: The Balance, 2 Pinfold Street, Sheffield, S1 2GU
Registered in England no: 03279013
For the benefit of others, my colleague figured this out. The smart ping doesn’t graph so when I’ve upgraded my RAW to Enterprise versions this stopped working – makes sense.
If you want this back, add a rule for Host Check Command and set it to Ping and they’ll be back.
Hope this helps someone else.
Kind regards,
James Poore
07483 300 413
Email:
jpoore@plus.net
Plusnet plc
From: checkmk-en checkmk-en-bounces@lists.mathias-kettner.de
On Behalf Of jpoore@plus.net
Sent: 08 July 2019 09:57
Subject: [Check_mk (english)] Host view, preview graphs
TIA for any input.
Kind regards,
James Poore
07483 300 413
Email:
jpoore@plus.net
Plusnet plc
Yes this is one of the drawbacks. It is documented here -
https://checkmk.com/cms_cmc_differences.html#The%20advantages
One disadvantage should not be hushed-up however: the Smart-Ping host checks generate no performance data (packet runtimes). On hosts where these are required you can simply set up a Ping-Check (via the Active Checks ➳ Check hosts with PING rule set).
Kind regards,
James Poore
07483 300 413
Email:
jpoore@plus.net
Plusnet plc
TIA for any input.
Kind regards,
James Poore
07483 300 413
Email:
jpoore@plus.net
Plusnet plc
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
