[Check_mk (english)] Hosts at different network
Hi everyone,
It’s my fist post, i’m very new to check_mk… although i’m an old user of nagios.
I have setup a new monitor server with omd and check_mk and i have added more than 80 servers, now i have to monitor servers that are located at local network which i can’t access directly from my monitor server.
Which is the best option? And how could i setup this servers? Distributed setup is the best option?
Thanks in advance!
Morala
Hi Hector,
you have some options.
  • setup a second server inside the remote network, make all the configuration there on this machine and only forward the livestatus data to your monitoring server.
→ this only needs one port for the livestatus communication
  • setup a second server and configure replication of configuration.
→ beside the livestatus port you need to configure http/s access to the remote server
Best regards
Andreas
Hector Morala Alvarez h.morala@gmail.com schrieb am Thu Feb 05 2015 at 18:51:43:
Hi everyone,
Thanks in advance!
Morala
checkmk-en mailing list
I think this is something miss-configured with the proxy settings. Do you setup apache proxy connection to get the graphs from the remote site?
If you work without proxy for the start all should work. But for further diagnosis the complete configuration of your site connections and your apache configuration is needed.
Best regards
Andreas
2015-02-10 18:45 GMT+01:00 Andreas Döhler andreas.doehler@gmail.com:
Hi Hector,
The remote installation will not send information to the central one as in such setups the central one will pull the information if needed.
Inside your OMD site you need to configure the livestatus port.
The complete Multisite part of documentation can be found here → http://mathias-kettner.de/checkmk.html#H1:Multisite
I don’t know a direct quickstart guide - only this link from the above documentation http://mathias-kettner.de/checkmk_multisite_setup.html
it is the old setup inside configuration files. The actual version uses WATO for site configuration.
Best regards
Andreas
Hector Morala Alvarez h.morala@gmail.com schrieb am Tue Feb 10 2015 at 17:45:39:
Thanks Andreas,
I have setup another omd installation in the the other network, in order tu check all hosts on this network.
Do you know any quickstart guide about how to send the information of this omd installation to my other/principal one?
thanks in advance
2015-02-05 21:32 GMT+01:00 Andreas Döhler andreas.doehler@gmail.com:
Hi Hector,
Best regards
Andreas
Hi everyone,
Thanks in advance!
Morala
Un saludo.
Morala
Un saludo.
Morala
