I’ve just installed 1.4.0p on Ubuntu 16.04LTS to upgrade my old instance (1.2.4), big changes! I am able to get into the check_mk web interface and set up a host but I cannot change the site password and as such cannot use the console to manage the site.
Can anyone share the secret sauce?
Hey Penny,
To change your password, you should update your user in “/omd/sites//etc/htpasswd” file.
https://httpd.apache.org/docs/2.2/programs/htpasswd.html
checkmk-en mailing list
Sebastian Smith
Systems Engineer
TruePath Technologies Inc.
Desk: (585) 672-5481
Thanks! I see ckadmin user in htpasswd and I tried that for su - but authentication failed. Like it’s not the same user?
Sebastian Smith
Systems Engineer
Do you mean that there is a unix system password set for your site user?
You are prompted for a password when you do su ?
If that is the case, then (as root) want to do a “passwd ”
That is how you change a system user password.
Sent from my iPad
On Aug 1, 2017, at 4:50 PM, Sebastian Smith ssmith@truepathtechnologies.com wrote:
Hey Penny,
Sebastian Smith
Systems Engineer
Email: ssmith@truepathtechnologies.com
Sebastian Smith
Systems Engineer
Thank you! That’s it!
Sent from my iPad
Hey Penny,
Sebastian Smith
Systems Engineer
Sebastian Smith
Systems Engineer
