thank you its work.
is this correct the RAM is not check?
CPU load
OK 05-22-2010 07:32:49 0d 8h 24m 47s 1/1 OK - 15min Load 0.22 at 2 CPUs
Check_MK
OK 05-22-2010 07:32:48 0d 8h 24m 49s 1/1 OK - Agent Version 1.1.4,
processed 7 host infos
Number of threads
OK 05-22-2010 07:32:49 0d 8h 24m 47s 1/1 OK - 91 threads
fs_/
OK 05-22-2010 07:32:49 0d 8h 24m 47s 1/1 OK - 1.9% used (0.7 of 36.4
GB), (levels at 80.0/90.0%)
fs_/export/home
OK 05-22-2010 07:32:49 0d 8h 24m 47s 1/1 OK - 1.1% used (0.1 of 9.8
fs_/opt
OK 05-22-2010 07:32:49 0d 8h 24m 47s 1/1 OK - 4.9% used (0.5 of 9.9
fs_/usr
OK 05-22-2010 07:32:49 0d 8h 24m 47s 1/1 OK - 15.1% used (3.0 of 19.7
fs_/var
On Fri, May 21, 2010 at 8:48 PM, Darin Perusich <Darin.Perusich@cognigencorp.com> wrote:
I you run "inetconv -f" it will overwrite the existing configuration.
On 05/21/2010 03:10 AM, Norman Vicente wrote:
seems like i have no success configuring sun solaris agent
what i did was
1. copy the check_mk_agent.solaris from the extracted agents.tar to /usr/bin/
2. add the following line to the end of /etc/inet/inetd.conf:
"check_mk stream tcp nowait root //usr/sfw/sbin/tcpd /usr/bin/check_mk_agent"
3. execute the inetconv
and stack from there
the result of inetconv
inetconv: Notice: Service manifest for check_mk already generated as
/var/mainfest/network/check_mk-tcp.xml. skipped
please help to fix this issue.
regards,
Norman
On Sat, May 15, 2010 at 12:41 AM, Norman Vicente >> <norman.vicente@gmail.com> wrote:
thanks Rajesh.
I will do this next week. is this thesame process with solaris 8 and 9?
regards,
norman
On Fri, May 14, 2010 at 5:36 PM, Bhardwaj, Rajesh >>> <rajesh.bhardwaj@capgemini.com> wrote:
You can perform following steps in Solaris 10. After copying /usr/share/check_mk/agents/check_mk_agent.solaris to Solaris 10 /usr/bin/
With Solaris 10, SMF is used. inetd entries can be converted to the SMF repository with the inetconv command. So first, add the following entry to /etc/services:
check_mk 6556/tcp # CheckMk
Then add the following line to the end of /etc/inet/inetd.conf:
Next, we need to convert it to SMF:
# inetconv
check_mk -> /var/svc/manifest/network/ check_mk-tcp.xml l
Importing check_mk-tcp.xml ...Done
# inetconv -e
svc:/network/check_mk/tcp:default enabled
Check to make sure it went online:
# svcs svc:/network/check_mk/tcp:default
STATE STIME FMRI
online Mar_19 svc:/network/check_mk/tcp:default
# netstat -a | grep check_mk
*.check_mk *.* 0 0 49152 0 LISTEN
Check the default installed parameters:
# inetadm -l svc:/network/check_mk/tcp:default
SCOPE NAME=VALUE
name="check_mk"
endpoint_type="stream"
proto="tcp"
isrpc=FALSE
wait=FALSE
exec="/usr/sfw/sbin/tcpd"
arg0="/usr/bin/check_mk_agent"
user="root"
default bind_addr=""
default bind_fail_max=-1
default bind_fail_interval=-1
default max_con_rate=-1
default max_copies=-1
default con_rate_offline=-1
default failrate_cnt=40
default failrate_interval=60
default inherit_env=TRUE
default tcp_trace=FALSE
tcp_wrappers=FALSE
default connection_backlog=10
Change it so that it uses tcp_wrappers:
# inetadm -m svc:/network/check_mk/tcp:default tcp_wrappers=TRUE
And check to make sure it took effect:
SCOPE NAME=VALUE
name="check_mk"
proto="tcp"
isrpc=FALSE
wait=FALSE
user="root"
Regards,
Rajesh
-----Original Message-----
From: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Norman Vicente
Sent: Friday, May 14, 2010 2:46 PM
Subject: [Check_mk (english)] how to install check_mk agent in sun solaris 8-10
I need your help to install check_mk agent in sun solaris 8-10 machines?
regards,
Norman
checkmk-en mailing list
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is
intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to
read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message
in error, please notify the sender immediately and delete all copies of this message.
Darin Perusich
Unix Systems Administrator
Cognigen Corporation
395 Youngs Rd.
Williamsville, NY 14221
Phone: 716-633-3463
Email: darinper@cognigencorp.com
is there any step to install check_mk agent on solaris 8?
On Sat, May 22, 2010 at 7:35 AM, Norman Vicente <norman.vicente@gmail.com> wrote:
thank you its work.
CPU load
Check_MK
Number of threads
fs_/
fs_/export/home
fs_/opt
fs_/usr
fs_/var
On Fri, May 21, 2010 at 8:48 PM, Darin Perusich > <Darin.Perusich@cognigencorp.com> wrote:
what i did was
regards,
Norman
On Sat, May 15, 2010 at 12:41 AM, Norman Vicente >>> <norman.vicente@gmail.com> wrote:
thanks Rajesh.
regards,
norman
On Fri, May 14, 2010 at 5:36 PM, Bhardwaj, Rajesh >>>> <rajesh.bhardwaj@capgemini.com> wrote:
# inetconv
# inetconv -e
STATE STIME FMRI
SCOPE NAME=VALUE
name="check_mk"
proto="tcp"
isrpc=FALSE
wait=FALSE
user="root"
tcp_wrappers=FALSE
SCOPE NAME=VALUE
name="check_mk"
proto="tcp"
isrpc=FALSE
wait=FALSE
user="root"
Regards,
Rajesh
regards,
Norman
Darin Perusich
395 Youngs Rd.
Phone: 716-633-3463
