[Check_mk (english)] How to monitor a windows process that is running as 32bit on a 64bit system
We are trying to monitor windows processes, and one of them is a 32bit process on a 64bit host and thus the process has a *32 after the process name and I’m not able to find a way to match this service, check_mk keeps saying no matching process found.
Any thoughts on how to do this?
Thanks
Jason
----- DISCLAIMER ----- This email (including any attachments) is confidential and may be subject to solicitor-client privilege. If you are not the intended recipient, you are hereby notified
that any use, distribution or copying of this email is prohibited. If you have received this email in error, please immediately notify me and permanently delete this email. Opinions expressed in this email are those of the sender and not of Toyota. Please scan
this email for viruses. Toyota does not accept any responsibility for problems caused by viruses, regardless of source.
Ce courriel (incluant toutes pièces jointes) est confidentiel et peut être assujetti au privilège du secret professionnel. Si vous n’êtes pas le destinataire visé,
nous vous avisons par la présente qu’il est interdit d’effectuer toute utilisation, toute distribution ou toute copie de ce courriel. Si vous avez reçu ce courriel par erreur, veuillez aviser immédiatement le soussigné et supprimer ce courriel de façon permanente.
Les opinions exprimées dans ce courriel sont celles de l’auteur et non de Toyota. Veuillez vérifier la présence de virus dans ce courriel. Toyota n’accepte aucune responsabilité pour des problèmes causés par les virus informatiques, peu importe la source.
Figured it out, the issue was case sensitivity…the server admin had passed me the process name in lowercase and it was in all uppercase in reality. To monitor
the 32bit process it was just the process name minus the *32.
Thanks
Jason
From: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de]
On Behalf Of Jason Humes (TCI)
Sent: Tuesday, July 19, 2016 1:29 PM
To: checkmk-en@lists.mathias-kettner.de checkmk-en@lists.mathias-kettner.de
Subject: [Check_mk (english)] How to monitor a windows process that is running as 32bit on a 64bit system
Thanks
Jason
----- DISCLAIMER ----- This email (including any attachments) is confidential and may be subject to solicitor-client privilege. If you are not the intended recipient, you are hereby notified that any use,
distribution or copying of this email is prohibited. If you have received this email in error, please immediately notify me and permanently delete this email. Opinions expressed in this email are those of the sender and not of Toyota. Please scan this email
Ce courriel (incluant toutes pièces jointes) est confidentiel et peut être assujetti au privilège du secret professionnel. Si vous n’êtes pas le destinataire visé, nous vous avisons par la présente qu’il est
interdit d’effectuer toute utilisation, toute distribution ou toute copie de ce courriel. Si vous avez reçu ce courriel par erreur, veuillez aviser immédiatement le soussigné et supprimer ce courriel de façon permanente. Les opinions exprimées dans ce courriel
