I want to capture Event ID 24 and Event ID 25 in the “Microsoft-Windows-TerminalServices-LocalSessionManager/Operational” log. I have tried to add this to the check_mk.ini
file logwatch section like I do for other logs. I seem to only be able to pull logs from the “Windows Logs” section but cannot pull anything from the “Application and Services Logs” section. Has anyone had any luck capturing these types of logs? I know
that they are “Information” logs, but I want to pull them in and count them. These logs represent a terminal server disconnection. I want to know if a server suddenly has a lot of these errors to determine if users are being disconnected.
Thanks,
**Ken Duncan |**Sr. Systems Engineer
DMSi Software| 402.330.6620 (e) 409
kduncan@dmsi.com |
dmsi.com
We deliver solutions that help our customers keep their promises and achieve outstanding results.
Hi Ken,
the monitoring for these internal Windows log files can be achieved with the new 1.4.0 agent. There it is possible to switch the log access to vista api.
The configuration inside check_mk.ini should look like the following lines
[logwatch]
activate modern eventlog api introduced in vista
pro: supports new logs introduced with vista
contra: only on vista (server 2008) and newer, less well tested, maybe slower
Note: setting this does not change the default set of monitored logs,
see logname for that
vista_api = yes
Activate a specific log. Unlike logfile this can be used to activate
monitoring of a new-style logfile (see vista_api) but it doesn’t
support wildcards (yet).
To find the correct name for a log, right-click on the log in
event-viewer → Properties and use the name from “Full Name”
logname Microsoft-Windows-TerminalServices-LocalSessionManager/Operational = warn
All other log files can be done the same way as before.
Normally don’t use an agent with older server versions. For the windows agent i can say that the 1.4.0b5 should also work correctly with an installed 1.2.8p20 on the server.
Don’t use newer plugin versions as there are some incompatible changes.
Save option is to wait until start of may this year. I think that at the Check_MK conference or the week before you will see the release of the final 1.4.0 version.
Best regards
Andreas
Ken Duncan kduncan@dmsi.com schrieb am Fr., 7. Apr. 2017 um 16:01 Uhr:
Thanks,
kduncan@dmsi.com |
dmsi.com
checkmk-en mailing list
Perfect! Thank you!
Thanks,
402.330.6620 (e) 409 |
kduncan@dmsi.com
Hi Ken,
[logwatch]
vista_api = yes
Best regards
Andreas
the check_mk.ini file logwatch section like I do for other logs. I seem to only be able to pull logs from the “Windows Logs” section but cannot pull anything from the “Application and Services Logs” section. Has anyone had any luck capturing these types
of logs? I know that they are “Information” logs, but I want to pull them in and count them. These logs represent a terminal server disconnection. I want to know if a server suddenly has a lot of these errors to determine if users are being disconnected.
Thanks,
kduncan@dmsi.com |
dmsi.com
Is it possible to set this to pull Information logs and then use regex to filter out logs?
Thanks,
kduncan@dmsi.com
From: checkmk-en [mailto:checkmk-en-bounces@lists.mathias-kettner.de]
On Behalf Of Ken Duncan
Sent: Tuesday, April 11, 2017 9:46 AM
To: Andreas Döhler andreas.doehler@gmail.com; checkmk-en@lists.mathias-kettner.de
Subject: Re: [Check_mk (english)] How to monitor Event Logs - Applications and Services Logs
Perfect! Thank you!
Thanks,
kduncan@dmsi.com
From: Andreas Döhler [mailto:andreas.doehler@gmail.com]
Sent: Monday, April 10, 2017 9:51 AM
To: Ken Duncan kduncan@dmsi.com;
Hi Ken,
[logwatch]
vista_api = yes
Best regards
Andreas
Thanks,
kduncan@dmsi.com |
dmsi.com
I don’t understand what you want to achieve? For windows logs it is only possible to filter with severity on the client side.
On the monitoring side you can then filter with regex the entries.
Best regards
Andreas
Ken Duncan kduncan@dmsi.com schrieb am Di., 11. Apr. 2017 um 17:21 Uhr:
Thanks,
kduncan@dmsi.com
Perfect! Thank you!
Thanks,
kduncan@dmsi.com
Hi Ken,
[logwatch]
vista_api = yes
Best regards
Andreas
Thanks,
kduncan@dmsi.com |
dmsi.com
My apologies, I was not clear. I did mean on the server side. I now have them coming and displaying in the logwatch.py page. Do you know if you can modify this page? I would like to group by hostgroup and chronologically base on host
name. Currently, the logwatch.py page just lists the hostnames in what seems like a completely random order.
Thanks,
kduncan@dmsi.com
Best regards
Andreas
Thanks,
kduncan@dmsi.com
Perfect! Thank you!
Thanks,
kduncan@dmsi.com
Hi Ken,
[logwatch]
vista_api = yes
Best regards
Andreas
tried to add this to the check_mk.ini file logwatch section like I do for other logs. I seem to only be able to pull logs from the “Windows Logs” section but cannot pull anything from the “Application and Services Logs” section. Has anyone had any luck capturing
these types of logs? I know that they are “Information” logs, but I want to pull them in and count them. These logs represent a terminal server disconnection. I want to know if a server suddenly has a lot of these errors to determine if users are being disconnected.
Thanks,
kduncan@dmsi.com |
dmsi.com
