All I really want to do is check to make sure that squid processes are running on these machines. Is there another way to check that and get a reliable answer?
Thanks,
Marc
On Tue, Feb 20, 2018 at 3:12 PM, Christopher Cox > <chriscox@endlessnow.com <mailto:chriscox@endlessnow.com>> wrote:
hmmm... oddly, the OSX agent (mine didnt) doesn't have a plugin
section. Rats... means you may have to embed it into the mac OSX
check_mk_agent file itself.
On 02/20/2018 03:59 PM, Marc Bruell wrote:
Thanks for the tip. Seeing the root prompt in the documentation
threw me, but your solution did the trick. When I change the
user to the one I specified in omd, I can find the check_mk command.
Given that I didn't install an agent on the mac, but just placed
the mac script on my macs, I don't believe I have a plugins
directory.
Once you install the mkp into your Check_MK, the Linux agent is
fairly generic. But requires that you have a program called
squidclient on your PATH when the agent on the Mac is called.
So, if you can execute squidclient (non-qualified) from a
shell on
your Macs,
I can't find a program called squidclient anywhere on my macs.
just copy the linux plugin into your local plugins dir on
your Mac
and it will likely work.
Is this the plugin I'd
use: /usr/share/sosreport/sos/plugins/squid.py
Where should I create the plugins directory on my macs?
Thanks,
Marc
On Tue, Feb 20, 2018 at 2:06 PM, Christopher Cox > <chriscox@endlessnow.com <mailto:chriscox@endlessnow.com> > <mailto:chriscox@endlessnow.com > <mailto:chriscox@endlessnow.com>>> wrote:
On 02/20/2018 03:02 PM, Marc Bruell wrote:
I installed check_mk raw 1.2.8p11 last year using OMD.
I love
it! However, I just tried to install the squid-1.3.mkp
check on
my check_mk server, and found that I don't have the
command:
check_mk which is used to install the extension.
You should have check_mk. Are you installing (properly) as the
monitor user (whatever user you used for that)?
Check to see who the OMD user for Ubuntu's install of
check_mk and
become that user to install the mkp
I'm running this on ubuntu 16.04.
Does installing check_mk via OMD exclude the check_mk
command?
Is there a way to add it? If not, is there another
command to
use to install extensions given an OMD based install?
checkmk-en mailing list
<mailto:checkmk-en@lists.mathias-kettner.de>
<mailto:checkmk-en@lists.mathias-kettner.de>>
<http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en>
<http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en>>
