I have a question about if it is possible to monitor VOIP and ILO services in SO Linux.
Cand some one please explain me how to configure these type of devices in CMK, and also what services can be monitored from them, if you can show me a screenshot of the configuration and the services i would appreciate it.
A little bit more explanation what you want to do would be good.
If these things are only normal running processes then you need to do nothing extra than only run the CMK agent on the target machine.
Inside CMK you can then specify a rule what processes you want to monitor.
