[Check_mk (english)] How to monitor XenServer
What is the best way to monitor xenserver?
with check_mk agent or snmp?
snmp is not showing much info.
agent is reporting many false/possessive.
###Sample messages:
few of:
Check_MK PROBLEM
(Service Check Timed Out)
too many of:
Vmalloc address space
CRIT - total 148.0 MB, used 11.7 MB, largest chunk 22.5 MB (critical at 32.0 MB!!)
tones of many different interface alerts:
Interface 17 PROBLEM
UNKNOWN - no such interface
Interface 12
WARN - [tap19.0] (up) MAC: fe:ff:ff:ff:ff:ff, 10MBit/s (wrong speed, expected: 0Bit/s)(!)
OK - [bond0.110] (up) MAC: zz:39:zz:02:zz:b0, speed unknown
Service description Interface 12
State
State OK → OK (FLAPPINGSTOP) since 0d 00:21:38
Output OK - [vif1zz0.0] (up) MAC: fe:ff:ff:ff:ff:ff, speed unknown, in: 4.25kB/s, out: 172.zzB/s
State
State OK → WARNING (PROBLEM) since 0d 00:00:01
Output WARN - [tap19.0] (up) MAC: fe:ff:ff:ff:ff:ff, 10MBit/s (wrong speed, expected: 0Bit/s)(!)
State
State
State WARNING → OK (FLAPPINGSTART) since 0d 00:00:00
Output OK - [vif1zz0.0] (up) MAC: fe:ff:ff:ff:ff:ff, speed unknown, in: 4.00MB/s, out: 8.41MB/s
Service description Interface 14
State
State WARNING → OK (FLAPPINGSTART) since 0d 00:00:01
Output OK - [vif12.0] (up) MAC: fe:ff:ff:ff:ff:ff, speed unknown, in: 3.56kB/s, out: 201.43kB/s
State
Output WARN - [tap85.0] (up) MAC: fe:ff:ff:ff:ff:ff, 10MBit/s (wrong speed, expected: 0Bit/s)(!)
Service description Interface 08
State
State OK → CRITICAL (PROBLEM) since 0d 00:00:07
Output CRIT - [bond0] (up) MAC: zz:9d:zz:30:zz:zz speed unknown, in: 241.66kB/s, in-errors: 19.59%(!!) = 0.1, out: 2.65kB/s
Service description Interface 07
State
State OK → CRITICAL (PROBLEM) since 0d 00:00:01
Output CRIT - [eth5] (up) MAC: zz:9d:zz:30:zz:zz, 10.00GBit/s, in: 239.21kB/s, in-errors: 27.92%(!!) = 0.1, out: 2.65kB/s
Service description Interface 10
State
Output CRIT - [bond0.110] (down)(!!) MAC: zz:39:zz:02:zz:zz, speed unknown
Regards,
Prashant Patel
It is best to use the agent. The output you gave are no false positive errors. You need to configure to ignore the virtual interfaces as these are not possible to monitor.
The Vmalloc check can be configured to not show this as error what you get.
Without good rules you will have many systems with “false positive” alerts.
Best regards
Andreas
Prashant Patel drsolaris8@gmail.com schrieb am Mi., 17. Juni 2015 um 21:18 Uhr:
###Sample messages:
few of:
Check_MK PROBLEM
too many of:
Interface 12
State
State
State
State
State
State
State
State
State
Regards,
Prashant Patel
checkmk-en mailing list
We’ll meet in Munich for the 2nd Check_MK Conference!
Book your place now and be part of it.
October 18th-20th, 2015
http://mathias-kettner.com/conference
