I configured a an aktive http-post check inside of WATO.
The http-get check worked, but since I want to test a login too, a co-worker defined a dummy loginuser, which should give a expected response.
For debugging I’d like to start that check from cli, but can’t find how to do it.
Frank Lienhard
Neos**IT GmbH
Schachtweg 1
38440 Wolfsburg
Tel. +49 5361 83494-32
Fax +49 5361 83494-94
mailto:frank.lienhard@neos-it.de
http://www.neos-it.de/
Handelsregister: Amtsgericht Braunschweig, HRB 203557
Geschäftsführer: Sven Wosny
Hi Frank,
If you select the full view of the appropriate service in multisite (click the service’s name) the resulting command is reported. You can use that command to invoke the command on command line ($USER1$ normally expands to the default location of the nagios plugin, $USER2$ to the plugin in the local folder).
HTH,
Marcel
2013/2/4 Lienhard, Frank Frank.Lienhard@neos-it.de
Frank Lienhard
Neos**IT GmbH
Schachtweg 1
38440 Wolfsburg
checkmk-en mailing list
Hi Frank,
I suppose you’ve no problem with mails in German?
In this thread (http://lists.mathias-kettner.de/pipermail/checkmk-de/2012-June/001701.html) the same questions have been asked and answered by Mathias Kettner…
HTH,
Marcel
2013/2/4 Marcel Schulte schulte.marcel@gmail.com
Hi Frank,
HTH,
Marcel
Frank Lienhard
Neos**IT GmbH
Schachtweg 1
38440 Wolfsburg
Tried that (sorry for not mentioned that earlier), but that command looks like this:
check_mk_active-http! -I $HOSTADDRESS$ -u ‘/path/to/secure-login/?do=doLogin&submit=true’ -p 8443 --ssl -e ‘Abmelden’ -P ‘forwardPage=&textUsername=dummy_user&textPassword=secret_passwd_for_dummy’ -T ‘text/html’ -j POST
But there isn’t a check_mk_aktive-http command (at least non that the siteusers nows of by starting it from his homedir.). So I think I still mis
something (perhaps opvious)
Frank
Von: Marcel Schulte [mailto:schulte.marcel@gmail.com]
Gesendet: Montag, 4. Februar 2013 12:42
An: Lienhard, Frank
Betreff: Re: [Check_mk (english)] How to start a check from cli?
Hi Frank,
HTH,
Marcel
Frank Lienhard
Neos**IT GmbH
Schachtweg 1
38440 Wolfsburg
Tel.
+49 5361 83494-32
Fax
+49 5361 83494-94
Hi Frank,
search for the nagios plugin ‘check_http’ (in OMD usually located in ~/lib/nagios/plugins/ (shipped) or ~/local/lib/nagios/plugins/ (customized)) and use this as binary.
…that’s the command defined for check_mk_active-http in ~/etc/nagios/conf.d/check_mk_objects.cfg:
define command {
command_name check_mk_active-http
command_line $USER1$/check_http $ARG1$
HTH,
Marcel
Frank
An: Lienhard, Frank
Hi Frank,
HTH,
Marcel
Frank Lienhard
Neos**IT GmbH
Schachtweg 1
38440 Wolfsburg
Tel.
+49 5361 83494-32
Fax
+49 5361 83494-94
