Good Morning Oliver,
Here are my results/versions/…
Check_MK: CEE 1.2.8.p16
psu_1.1
1
1194
508
337
612
321
29
psu_1.2
1
1195
508
337
867
379
29
psu_2.1
2
1198
508
336
195
299
29
psu_2.2
2
1194
507
336
476
270
29
psu_3.1
3
1213
515
364
255
208
29
psu_3.2
3
1213
515
362
401
171
29
Controller Modules:
Component Controller A Controller B
Bundle Version GL220P008 GL220P008
Storage Controller Code Version GLS220R09-02 GLS220R09-02
Storage Controller Loader Code Version 27.016 27.016
Memory Controller FPGA Code Version N/A N/A
Management Controller Code Version GLM220R009-10 GLM220R009-10
Management Controller Loader Code Version 6.18.22216 6.18.22216
Expander Controller Code Version 3203 3203
CPLD Code Version 55 55
Expansion Modules:
Enclosure Module Position Part Number Code Version Bus ID Target ID
2 A Top 717873-001 2038 00 127
2 B Bottom 717873-001 2038 01 127
3 A Top 717873-001 2038 00 191
3 B Bottom 717873-001 2038 01 191
Regarding the “Power supply module voltage sensors” information… very helpful J
For the mailing list members I write it in letters again, because attachments are limited to totally <= 60kB
Power supply voltage 12V - Fault LED condition for:
< 11.00V
13.00V
Power supply voltage 5V - Fault LED condition for:
< 4.00V
6.00V
Power supply voltage 3.3V - Fault LED condition for:
< 3.00V
3.80V
Best regards
Stefan
Stefan Marleaux
Senior Project Engineer
Axino Solutions GmbH
Charlottenburger Allee 61, 52068 Aachen, Deutschland
T +49 241 96806 293
M +49 160 90922974
F +49 241 96806 225
Stefan.Marleaux@axino-group.com
Sitz der Gesellschaft und Registergericht: Aachen Nr. 20143
Geschäftsführer: Michael E. Wallrath
Von: Oliver O’Boyle [mailto:ooboyle@atlific.com]
Gesendet: Dienstag, 7. Februar 2017 19:25
An: Marleaux, Stefan Stefan.Marleaux@axino-group.com; checkmk-en checkmk-en@lists.mathias-kettner.de
Betreff: RE: [Check_mk (english)] hp_msa datasource power supply voltage not displaying voltage
Ok, so it looks like the MSA (or the API, at least) is not returning any values for the two additional enclosures. You can check this if you log in to the web interface then browse to: http(s):///v3/api/show/power-supplies
Below is a sample (with only the relevant output fields included) of one of the psu’s from one of the additional enclosures. The reading are the same for all psu’s on both additional enclosures so I won’t paste additional samples of them here:
psu_2.1
2
PSU 1, Upper
Enclosure 2 - Upper
0
0
0
0
0
The highlighted 0’s should not be there. Results from the psu’s on the first enclosure have positive numbers there such as 1202, 507, 337 etc…
So this is looking like a firmware bug, I guess…
Here’s what I’m running:
What version are you running?
Oliver
From: Marleaux, Stefan [mailto:Stefan.Marleaux@axino-group.com]
Sent: February-07-17 3:17 AM
To: checkmk-en checkmk-en@lists.mathias-kettner.de
Cc: Oliver O’Boyle ooboyle@atlific.com
Subject: AW: [Check_mk (english)] hp_msa datasource power supply voltage not displaying voltage
Hello Oliver,
I have the problem too. Not all enclosures have this problem. I tried to find some technical documentation from HP but I couldn’t find any document which describes what range is ok and what range is critical. Maybe the “package owner” has some more information.
Meanwhile I changed the parameters for this check. Hint: There is a small bug for the 5V levels – there are wrong text description fields but if you change them they values are working. I already wrote this problem to the mailing list ()
Best regards
Stefan
Von: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de] Im Auftrag von Oliver O’Boyle
Gesendet: Montag, 6. Februar 2017 19:22
An: checkmk-en checkmk-en@lists.mathias-kettner.de
Betreff: [Check_mk (english)] hp_msa datasource power supply voltage not displaying voltage
Hi list,
I’ve added the HP MSA datasource and am monitoring an HP 2040 MSA. All check work as expected except the Power Supply Voltage check for additional enclosures. The check DOES work for the primary enclosure.
Here is the output for enclosures 2 and 3 (both power supplies in each enclosure show this):
Here is the output for enclosure 1 (both power supplies in the enclosure show this):
I’m on cmk 1.2.8p4 RAW.
Any advice on how to get this to work?
Oliver
Oliver O’Boyle
Director, IT • Atlific Hotels
250 Saint-Antoine W., Suite 400 Montreal, Quebec H2Y 0A3
T: 514.509.5545 C: 514.608.8533 F: 514.509.5498
ooboyle@atlific.com www.atlific.com
Stefan Marleaux
T +49 241 96806 293
M +49 160 90922974
F +49 241 96806 225
