PAYMENT-iT
Gesellschaft für Zahlungssysteme und
Kartenprocessing mbH
Schleißheimer Straße 141, 80797 München,
Germany
Tel.: +49 89 54 59 32-0
Fax: +49 89 54 59 32-99
Handelsregister: München HRB 178824
USt-IdNr: DE 181905203
Geschäftsführung: Horst-Dieter Koch,
Thomas Rafalski
www.payment-it.com
Von:
Evy
Bongers lists+check-mk@evybongers.nl
An:
Michael
von Hünerbein Michael.vonHuenerbein@payment-it.com,
Kopie:
Datum:
13.06.2017
11:56
Betreff:
Re:
[Check_mk (english)] HTTP check - How to configure https client certificate
`Hi Michael,
The check plugin does support this.
OMD[test]:~$ lib/nagios/plugins/check_http --help
check_http v2.2 (monitoring-plugins 2.2)
Copyright (c) 1999 Ethan Galstad nagios@nagios.org
Copyright (c) 1999-2013 Monitoring Plugins Development Team
<devel@monitoring-plugins.org>
This plugin tests the HTTP service on the specified host. It can
test
normal (http) and secure (https) servers, follow redirects, search
for
strings and regular expressions, check connection times, and report
on
certificate expiration times.
-J, --client-cert=FILE
Name of file that contains the client certificate
(PEM format)
to be used in establishing the SSL session
-K, --private-key=FILE
Name of file containing the private key (PEM format)
matching the client certificate
Unfortunately, WATO does not provide a way to configure this.
You could configure your HTTP check through ‘Hosts & Service parameters’
‘Active checks (HTTP, TCP, etc.)’ > ‘Classical active and passive
Monitoring checks’ and then provide the necessary parameters by hand.
You will need to upload the certificates to the server in order for this
to work.
Regards,
Evy
On 2017-06-13 09:03, Michael von Hünerbein wrote:
Hello All,
we need to check availability of our web application externally using
a
client certificate., however cannot figure out how to get that
configured.
We are using CMK 1.2.8 Enterprise Edition.
Does somebody know how to set up the HTTP check using a client
certificate?
Thanks in advance an regards
Mit freundlichen Grüßen
PAYMENT-iT
Gesellschaft für Zahlungssysteme und Kartenprocessing mbH
Schleißheimer Straße 141, 80797 München, Germany
Geschäftsführung: Horst-Dieter Koch, Thomas Rafalski
[www.payment-it.com](www.payment-it.com)
checkmk-en mailing list
[http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en`](http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en)`
