Hi again list!
I’m trying to test all possibilities of check_mk before continue writing my plugins and I’m stuck with something as simple as Software / Hardware inventory.
Initially I just enabled it on WATO and it only show a little info about RAM.
Now, knowing a little bit more about Check_mk internals and reading online docs (I know it can be outdated) I realized that in order to get true HW/SW inventory, I had to copy mk_inventory.linux plugin into agent plugins folder.
…well, I did it, and it does not work
Since HW/SW is an active check (from what I read and guess) I’m not sure whethter or not is it normal that agent plugin output is not present on passive check (normal) output
I have verified this both by running telnet 6556 and with cmk -d command … no mk_inventory.linux output added.
By examining the shell script itself I see it uses an interval control algorithm, but I cannot dig further.
Running manually the script creates a file in root filesystem /mk_inventory.last. since $MK_CONFDIR, $MK_VARDIR or $REMOTE variables are blank…
What am I missing? how could I troubleshoot this? does active check use a different port other than 6556? Is there some setup in WATO? I see in WATO the rule does not need configuration…
If you have, check that the directory you put it in matches the
directory listed in the <<<check_mk>>> section
of the agent output as PluginsDirectory.
Regards,
Paul
On 07/07/16 12:47, Alejandro Olivan
Alvarez wrote:
Hi again list!
…well, I did it, and it does not work�
filesystem �/mk_inventory.last. since $MK_CONFDIR, $MK_VARDIR
configuration…
Could some one help me?
Thank you in advance…
checkmk-en mailing list
