[Check_mk (english)] Inventory / monitoring of Linksys SGE2010 with SNMP
Hi all,
I have been trying to add my SGE2010 stack to my OMD installation, but I can’t get the inventory to find all the available interfaces on the system and add them to the monitoring interface. Using SNMP v2 causes the inventory
to fail, but I managed to get it to work on the command line using SNMP v1 (it timed out using the web GUI though). Now I have several checks, but the interface reports that the check times out. Snmpwalk and snmpbulkwalk are also extremely slow…
This seems to be more of a switch problem than a Check_MK problem… but I would be very happy to hear your thoughts. I am running OMD 0.56 and Check_MK 1.2.0p2. I saw the following
threads with the similar problems but no answers:
http://lists.mathias-kettner.de/pipermail/checkmk-en/2010-December/002250.html
http://lists.mathias-kettner.de/pipermail/checkmk-de/2011-October/001307.html
Thanks a million,
  • Tim
Hi Tim,
1.) Timeouts/slowness:
it’s most likely a switch problem. You should try tweaking nagios’ service_check_timeout variable (default set to 60 sec, set this to a higher value, maybe 120 or even higher). This can be done by adding “service_check_timeout=120” to your ~/etc/nagios/nagios.cfg and restart/reload (“cmk-R”/“cmk -O”).
2.) Interfaces:
check which porttype is reported by the switch (snmpwalk -v1 -c .1.3.6.1.2.1.2.2.1.3). Most likely cmk does not know the porttype should be inventorized. Which porttypes are inventorized can be checked in WATO → Global Settings → Check configuration → Network interface port types to inventorize. This setting can only be specified in global scope for current stable release of cmk. In git-/dev-release this setting can be done in rules and therefor inherited by folders, tags, …
HTH,
Marcel
2013/2/5 Timothée Guicherd timg@ipconnect.com.au
Hi all,
Thanks a million,
  • Tim
checkmk-en mailing list
Just give up with this type of switch. Snmp is a joke on it.
Hi all,
the inventory to fail, but I managed to get it
answers:
Thanks a million,
  • Tim
Did anyone have luck getting this going? I now have to monitor a Linksys SGE-2000P stack.
I am running omd-0.57.20130522-rh61-30.x86_64
I have interface type ethernetCsmacd(6), propVirtual(53) enabled.
I ran a “snmpwalk -On -v2c -c $USER20$ $HOSTADDRESS$ | grep 1.3.6.1.2.1.2.2.1.3”
.1.3.6.1.2.1.2.2.1.3.1 = INTEGER: ethernetCsmacd(6)
.1.3.6.1.2.1.2.2.1.3.100018 = INTEGER: propVirtual(53)
Thanks,
/Chris C
On Tue, Feb 5, 2013 at 5:49 AM, Marcel Schulte schulte.marcel@gmail.com wrote:
Hi Tim,
2.) Interfaces:
HTH,
Marcel
Hi all,
Thanks a million,
  • Tim
Snmpbulkwalk doesn’t seem to be stable on the Linksys SGE-2000P. Command line snmpbulkwalk commands fail.
I created a WATO rule in Host & Service Parameters / Access to Agents / Hosts using SNMP v2c (and no bulk walk)
The host still seems to be using bulkwalk.
OMD[atd]:~$ cmk -IIu --debug linksys_stack
Scanning host linksys_stack(192.168.169.11) for SNMP checks…Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.2.1.1.1.0 2>/dev/null’
SNMP answer: ==> [“24-port 10/100/1000 Ethernet Switch”]
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.231.2.10.2.1.1.0 2>/dev/null’
SNMP answer: ==> [No Such Object available on this agent at this OID]
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.2.1.1.2.0 2>/dev/null’
SNMP answer: ==> [.1.3.6.1.4.1.3955.7.4.2000.2]
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.12356.1.8.0 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.232.2.2.4.2.0 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.2.1.25.1.1.0 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 1.3.6.1.2.1.1.1.0 2>/dev/null’
Running ‘snmpgetnext -Cf -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.2.1.31.1.1.1.6 2>/dev/null’
SNMP answer: ==> [10989484759]
if64 Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.2.1.43.11.1.1.6.1.1 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.2.1.43.10.2.1.4.1.1 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.789.1.2.1.3.0 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.2.1.1.4.0 2>/dev/null’
SNMP answer: ==> [“Doug Hairfield”]
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.789.1.17.20.0 2>/dev/null’
snmp_info Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.3854.1.1.6.0 2>/dev/null’
snmp_uptime Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.9.9.48.1.1.1.6.1 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.12356.1.9.0 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.1602.1.1.1.1.0 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.12356.1.10.0 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.2.1.2.1.0 2>/dev/null’
SNMP answer: ==> [214]
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 1.3.6.1.2.1.1.2.0 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.4.1.9.9.109.1.1.1.1.5.1 2>/dev/null’
Running ‘snmpget -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 192.168.169.11 .1.3.6.1.2.1.33.1.1.1.0 2>/dev/null’
Trying inventory for if64 on linksys_stack
Running snmpbulkwalk -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 192.168.169.11 .1.3.6.1.2.1.2.2.1.1 2>/dev/null
Running snmpbulkwalk -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 192.168.169.11 .1.3.6.1.2.1.2.2.1.2 2>/dev/null
Running snmpbulkwalk -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 192.168.169.11 .1.3.6.1.2.1.2.2.1.3 2>/dev/null
ERROR: SNMP error
Host ‘linksys_stack’: SNMP Error on 192.168.169.11
Trying inventory for snmp_info on linksys_stack
Running snmpbulkwalk -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 192.168.169.11 .1.3.6.1.2.1.1.1.0 2>/dev/null
ERROR: SNMP error
Trying inventory for snmp_uptime on linksys_stack
Running snmpbulkwalk -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 192.168.169.11 .1.3.6.1.2.1.1.3.0 2>/dev/null
snmp_uptime 1 new checks
Thanks,
/Chris C
Thanks,
/Chris C
Hi Tim,
2.) Interfaces:
HTH,
Marcel
Hi all,
Thanks a million,
  • Tim
If I run a manual snmpwalk against the oid tree i get data returned
OMD[atd]:~/etc/check_mk/conf.d$ snmpwalk -v2c -c ‘L0lCatz’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 192.168.169.11 .1.3.6.1.2.1.1.3.0
.1.3.6.1.2.1.1.3.0 = 362736486
Is there a way to force a host/tag to do snmp v2c but not snmpbulkwalk?
Thanks,
/Chris C
ERROR: SNMP error
ERROR: SNMP error
Thanks,
/Chris C
Thanks,
/Chris C
Hi Tim,
2.) Interfaces:
HTH,
Marcel
Hi all,
Thanks a million,
  • Tim
