Hi All,
How can I monitor IP SLA for Cisco. Do you have some plugins/checks for this or maybe how you monitor this?
Pozdrawiam,
Radosław Bąk
IPOPEMA Securities S.A.
ul. Próżna 9, 00-107 Warszawa
tel. +48 22 236 9278
tel. kom. +48 667 953 265
www.ipopema.pl
Hi All,
I found working check for Cisco IP SLA here
http://comments.gmane.org/gmane.network.nagios.checkmk/4411 if somebody
wants
Descrition of this check:
„This check monitors IP SLA monitoring instances on Cisco
devices. Currently only SLA instances of type icmp-echo
are supported.
Depending on the state of the SLA monitor the checks can
be {OK}, {CRIT} or {UNKNOWN}.”
Mathias/Check_MK/OMD team,
Maybe you can add this check to official version?
Pozdrawiam,
Radosław Bąk
-----Original Message-----
[mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Radosław
Bąk
Sent: Friday, March 08, 2013 2:41 PM
Subject: [Check_mk (english)] IP SLA for Cisco check
Hi All,
Pozdrawiam,
Radosław Bąk
www.ipopema.pl
checkmk-en mailing list
And one thing - maybe someone of you can try to write/change this check for
monitor icmp-jiter and udp-jiter (because below monitors only icmp-echo)?
Pozdrawiam,
Radosław Bąk
From: Radosław Bąk [mailto:radoslaw.bak@ipopema.pl]
Sent: Tuesday, March 19, 2013 11:33 AM
To: 'Radosław Bąk'; checkmk-en@lists.mathias-kettner.de
Subject: RE: [Check_mk (english)] IP SLA for Cisco check
Importance: High
Hi All,
wants
„This check monitors IP SLA monitoring instances on Cisco devices. Currently
only SLA instances of type icmp-echo are supported.
Depending on the state of the SLA monitor the checks can be {OK}, {CRIT} or
{UNKNOWN}.”
Pozdrawiam,
Radosław Bąk
Bąk
Hi All,
Pozdrawiam,
Radosław Bąk
www.ipopema.pl
