Hello Team,
I am looking for IPMI / IDRAC disk monitoring along with RAID status.Is there any way to monitor these checks on WATO.
Current OMD version is 1.31.20160602
Check_mk: 1.2.6.p12
https://mathias-kettner.de/checkmk_check_dell_idrac_disks.html
I have found through documentation but i don’t have any clue how to enable checks
I send a message to the mailing list about this yesterday
I believe this is broken.
that what you should do:
enable snmp in the idrac
configure in wato a host using the idrac ip and use snmp as agent
but check_mk is not able to discover anything… running check_mk in debug mode it queries oid not existing in the mib of the idracs.
I hope someone will answer.
From: checkmk-en-bounces@lists.mathias-kettner.de checkmk-en-bounces@lists.mathias-kettner.de on behalf of Pradeep Kns knspradeep.blogs@gmail.com
Sent: Wednesday, January 18, 2017 6:52:05 PM
Subject: [Check_mk (english)] IPMI / IDRAC monitoring on DISKS & RAID status
Hello Team,
Check_mk: 1.2.6.p12
Mario Garcia Ortiz
System Engineer
ASP - Advanced Service Provider
Tel: +32 (0)2 333 40 70
Humaniteitslaan 228 Boulevard de l’Humanité | 1190 Brussels
Hi Pradeep,
I had the same problem with our VRTX blade chassis a while ago. The OID that is checked by CMK for the disks doesn't exist on our VRTX. I browsed the vendor supplied MIB for any information about disks, but couldn't find anything except trap definitions (which are not usable for active checks). To me it looks like HP doesn't provide any way to check the disk status via SNMP for at least some devices.
We have given up on this, but you can ask your vendor which SNMP OIDs to use for this and build a custom check (https://mathias-kettner.de/checkmk_devel_snmpbased.html) or pay Mathias Kettner to do this.
Kind Regards,
Dominik Eismann
http://www.wieland-electric.com/de/aktuelles/messen-und-termine
Wieland Electric GmbH
Sitz: Brennerstrasse 10-14, D-96052 Bamberg
Geschaeftsfuehrer: Dr. Oliver Eitrich, Dr. Ulrich Schaarschmidt
Registergericht: AG Bamberg HRB 105
Der Inhalt dieser Mail enthaelt moeglicherweise vertrauliche Informationen und ist ausschliesslich fuer den bezeichneten Adressaten bestimmt.
Wenn Sie nicht der richtige Adressat sind, teilen Sie dem Absender bitte den Erhalt der Mail mit und loeschen Sie die Mail.
The content of this mail may contain confidential information and is intended solely for the designated addressee.
If you are not the intended addressee, then please inform the sender the receipt of this mail and delete the E-Mail.
