Hello everybody,
we just updated checkmk from 1.5 to 1.6, and it went ok except
for some small things.
The main issue has to do with the HP hardware Raid check.. on all
servers with that controller we’re getting this 2 warnings:
UNKN - The discovery function
“inventory_hpsa_controller” of the check “hpsa_controller” is
expected to take a single argument (info or parsed), but it’s
taking the following arguments: [‘checkname’, ‘info’]. You will
have to change the arguments of the discovery function to make it
compatible with this Checkmk version.
“inventory_hpsa_array” of the check “hpsa_array” is expected to
take a single argument (info or parsed), but it’s taking the
following arguments: [‘checkname’, ‘info’]. You will have to
I think I had installed the hpsa-3.1.mkp
(https://checkmk.de/check_mk-exchange-file.php?file=hpsa-3.1.mkp )
on the 1.5 version, but I really don’t know what to do or to
change to fix this… It says to change the arguments… but
where, and to what arguments?
Could you help me?
Thanks a lot
Cheers
Signature
Flávio
Moringa
Head Infrastructure Engineer
Know more about our company - www.aptoide.com
I’ve found what I needed, so here it is for future knowledge:
There is an update to the extension, version 5.1, that works on
1.6.
Hope it helps
https://github.com/HeinleinSupport/check_mk_extensions/tree/master/hpsa
Signature
Flávio
Moringa
Às 09:08 de 30/10/19, Flávio Moringa
escreveu:
Hello everybody,
all servers with that controller we’re getting this 2 warnings:
it compatible with this Checkmk version.
hpsa-3.1.mkp (https://checkmk.de/check_mk-exchange-file.php?file=hpsa-3.1.mkp )
Could you help me?
Thanks a lot
Cheers
Signature
Flávio
Moringa
Head Infrastructure
Engineer
- www.aptoide.com
checkmk-en mailing list
checkmk-en@lists.mathias-kettner.dehttps://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
