[Check_mk (english)] Issues with HP StoreVirtual via SNMP (1.2.8p4)
I’m having problems with a device that was previously working on 1.2.7 latest, it’s a HP StoreVirtual 4730.
Hi Nathan,
does this also happen when you configure the host as SNMPv1 inseatd of SNMPv2c? I fit does not the issue could be bulkwalk (not available in v1). Some devices don’t like it very much. If that’s the case you can also try configuring the host to use v2c without bulk:
1st: configure host as legacy SNMP device
2nd: WATO → Host & service parameters → Access to agents → Legacy SNMP devices using SNMP v2c
HTH,
Marcel
Nathan Alberti nathan@reseau.com.au schrieb am Do., 9. Juni 2016 um 11:13 Uhr:
Scanning for services yields a timeout with whatever setting I have (3-15sec)
Inline SNMP on or off
Seems to get stuck/hangs polling OID .1.3.6.1.4.1.232.6.2.14.13.1.20 which should be memory details
Debug output is below
Just trying to establish if check_mk is asking for something it shouldn’t be and the SNMP agent crashing (on the SAN) or an error is not being gracefully handled.
Running snmpwalk -v1 -c ‘public’ -OQ -OU -On IP Addr .1.3.6.1.4.1.232.6.2.14.13.1.20 2>/dev/null
HW Mem 0 OK - Board: 0, Num: 0, Type: n/a, Size: 512 MB, Status: good , Condition: ok ()
HW Mem 1 OK - Board: 0, Num: 1, Type: n/a, Size: 512 MB, Status: good , Condition: ok ()
HW Mem 2 OK - Board: 0, Num: 2, Type: n/a, Size: 2048 MB, Status: good , Condition: ok ()
HW Mem 3 OK - Board: 0, Num: 3, Type: n/a, Size: 2048 MB, Status: good , Condition: ok ()
HW Mem 4 OK - Board: 0, Num: 4, Type: n/a, Size: 2048 MB, Status: good , Condition: ok ()
HW Mem 5 OK - Board: 0, Num: 5, Type: n/a, Size: 2048 MB, Status: good , Condition: ok ()
OMD[reseau]:~/var/check_mk$ snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.14.13.1.20
.1.3.6.1.4.1.232.6.2.14.13.1.20.0 = 2
.1.3.6.1.4.1.232.6.2.14.13.1.20.1 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.2 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.3 = 2
.1.3.6.1.4.1.232.6.2.14.13.1.20.4 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.5 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.6 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.7 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.8 = 2
.1.3.6.1.4.1.232.6.2.14.13.1.20.9 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.10 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.11 = 2
.1.3.6.1.4.1.232.6.2.14.13.1.20.12 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.13 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.14 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.15 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.16 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.17 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.18 = 1
.1.3.6.1.4.1.232.6.2.14.13.1.20.19 = 1
Timeout: No Response from 172.16.2.31:161
OMD[reseau]:~/var/check_mk$ check_mk --debug -Ivvvvv res-per-hpsas1.reseau.net.au
Discovering services on res-per-hpsas1.reseau.net.au:
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.2.1.1.1.0’
SNMP answer: ==> [“Linux res-per-hpsan1 2.6.32-431.11.2.el6.x86_64 #1 SMP Sat Feb 14 12:48:35 MST 2015 x86_64”]
Getting OID .1.3.6.1.2.1.1.2.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.2.1.1.2.0’
SNMP answer: ==> [.1.3.6.1.4.1.8072.3.2.10]
Getting OID .1.3.6.1.4.1.231.2.10.2.1.1.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.4.1.231.2.10.2.1.1.0’
SNMP answer: ==> [No Such Object available on this agent at this OID]
failed.
Getting OID .1.3.6.1.2.1.1.6.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.2.1.1.6.0’
SNMP answer: ==> [“Perth DC”]
Perth DC
Getting OID .1.3.6.1.4.1.232.2.2.4.2.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.2.2.4.2.0’
SNMP answer: ==> [“ProLiant DL380p Gen8”]
Getting OID .1.3.6.1.2.1.43.11.1.1.6.1.1: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.2.1.43.11.1.1.6.1.1’
failed.
Getting OID .1.3.6.1.2.1.43.10.2.1.4.1.1: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.2.1.43.10.2.1.4.1.1’
failed.
Getting OID .1.3.6.1.2.1.25.1.1.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.2.1.25.1.1.0’
SNMP answer: ==> [3739627053]
3739627053
Getting OID .1.3.6.1.4.1.14848.2.1.1.1.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.4.1.14848.2.1.1.1.0’
failed.
Getting OID .1.3.6.1.4.1.6574.3: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.4.1.6574.3’
failed.
Getting OID .1.3.6.1.4.1.6574.*: Running ‘snmpgetnext -Cf -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.4.1.6574’
SNMP answer: ==> [“”]
failed.
Getting OID .1.3.6.1.2.1.31.1.1.1.6.*: Running ‘snmpgetnext -Cf -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.2.1.31.1.1.1.6’
SNMP answer: ==> [5926768951048]
5926768951048
Getting OID .1.3.6.1.2.1.33.1.1.1.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.2.1.33.1.1.1.0’
failed.
Getting OID .1.3.6.1.4.1.6302.2.1.1.1.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.4.1.6302.2.1.1.1.0’
failed.
Getting OID .1.3.6.1.2.1.2.1.0: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.2.1.2.1.0’
SNMP answer: ==> [8]
8
Getting OID .1.3.6.1.4.1.6574.1: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.4.1.6574.1’
failed.
Getting OID .1.3.6.1.4.1.6574.2: Running ‘snmpget -v2c -c ‘public’ -m ‘’ -M ‘’ -On -OQ -Oe -Ot 172.16.2.31:161 .1.3.6.1.4.1.6574.2’
failed.
SNMP scan found: hp_proliant_psu snmp_info hr_mem hp_proliant_da_cntlr bgp_peer hp_proliant_da_phydrv fast_lta_silent_cubes.capacity ucd_cpu_load hp_proliant_fans hp_proliant_mem fast_lta_headunit.status
fast_lta_headunit.replication if64 snmp_uptime hr_cpu hp_proliant_temp hp_sts_drvbox dell_om_disks dell_om_sensors hr_fs fast_lta_volumes hp_proliant_cpu dell_om_esmlog hp_proliant_raid dell_om_processors hp_proliant dell_om_mem hp_proliant_power
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.3
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.4
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.5
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.7
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.9
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.10
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.11
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.15.3.1.14
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.4
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.6
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.9
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.10
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.15
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.11
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.21
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.22
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.31
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10893.1.20.130.4.1.35
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.200.10.1.41.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.1100.50.1.8.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.1100.50.1.5.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.1100.50.1.14.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.1100.50.1.20.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.1100.30.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.1100.30.1.5
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.1100.30.1.8
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.1100.30.1.9
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.1100.32.1.6
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.700.20.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.700.20.1.5
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.700.20.1.6
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.700.20.1.8
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.700.20.1.10
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.700.20.1.11
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.700.20.1.12
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.674.10892.1.700.20.1.13
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.27417.2.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.27417.2.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.27417.2.5
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.27417.3.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.27417.3.3
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.27417.5.1.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.27417.5.1.1.9
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.27417.5.1.1.11
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.11.1.3.0
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.11.2.14.1.1.5.0
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.2.2.2.1.0
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.1.2.2.1.1.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.1.2.2.1.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.1.2.2.1.1.3
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.1.2.2.1.1.6
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.2.1.1.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.2.1.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.2.1.1.5
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.2.1.1.6
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.2.1.1.8
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.2.1.1.9
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.2.1.1.10
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.2.1.1.12
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.2.1.1.15
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.5.1.1.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.5.1.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.5.1.1.5
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.5.1.1.6
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.5.1.1.9
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.5.1.1.45
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.5.1.1.37
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.5.1.1.50
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.3.2.5.1.1.57
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.6.7.1.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.6.7.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.6.7.1.3
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.6.7.1.4
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.6.7.1.6
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.6.7.1.9
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.6.7.1.12
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.14.13.1.2
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.14.13.1.1
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.14.13.1.6
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.14.13.1.7
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.14.13.1.19
Running snmpbulkwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.232.6.2.14.13.1.20
ERROR: SNMP error: Timeout: No Response from 172.16.2.31:161
File “/omd/sites/reseau/share/check_mk/modules/check_mk.py”, line 5255, in
do_discovery(hostnames, check_types, seen_I == 1)
File “/omd/sites/reseau/share/check_mk/modules/discovery.py”, line 74, in do_discovery
do_discovery_for(hostname, check_types, only_new, use_caches, on_error)
File “/omd/sites/reseau/share/check_mk/modules/discovery.py”, line 94, in do_discovery_for
new_items = discover_services(hostname, check_types, use_caches, do_snmp_scan, on_error)
File “/omd/sites/reseau/share/check_mk/modules/discovery.py”, line 628, in discover_services
for item, paramstring in discover_check_type(hostname, ipaddress, check_type, use_caches, on_error):
File “/omd/sites/reseau/share/check_mk/modules/discovery.py”, line 755, in discover_check_type
info = get_info_for_discovery(hostname, ipaddress, section_name, use_caches)
File “/omd/sites/reseau/share/check_mk/modules/discovery.py”, line 527, in get_info_for_discovery
ignore_check_interval=True, use_snmpwalk_cache=False)
File “/omd/sites/reseau/share/check_mk/modules/check_mk_base.py”, line 475, in get_realhost_info
table = get_snmp_table(hostname, ipaddress, check_type, oid_info, use_snmpwalk_cache)
File “/omd/sites/reseau/share/check_mk/modules/snmp.py”, line 163, in get_snmp_table
rowinfo = get_snmpwalk(hostname, ip, check_type, oid, fetchoid, column, use_snmpwalk_cache)
File “/omd/sites/reseau/share/check_mk/modules/snmp.py”, line 225, in get_snmpwalk
rowinfo = perform_snmpwalk(hostname, ip, check_type, oid, fetchoid)
File “/omd/sites/reseau/share/check_mk/modules/snmp.py”, line 246, in perform_snmpwalk
rows = snmpwalk_on_suboid(hostname, ip, fetchoid, context_name=context_name)
File “/omd/sites/reseau/share/check_mk/modules/snmp.py”, line 617, in snmpwalk_on_suboid
raise MKSNMPError(“SNMP Error on %s: %s (Exit-Code: %d)” % (ip, error.strip(), exitstatus))
main.MKSNMPError: SNMP Error on 172.16.2.31: Timeout: No Response from 172.16.2.31:161 (Exit-Code: 1)
Regards,
Nathan Alberti
checkmk-en mailing list
That fixed it, not sure how/why it was working previously with no specific configuration.
Thanks for your help.
SNMP scan:
failed.
Perth DC
failed.
failed.
SNMP answer: ==> [3745947560]
3745947560
failed.
failed.
SNMP answer: ==> [""]
failed.
SNMP answer: ==> [5939195927449]
5939195927449
failed.
failed.
8
failed.
failed.
ucd_cpu_load hp_proliant_fans hp_proliant_mem fast_lta_headunit.status fast_lta_headunit.replication if64 snmp_uptime hr_cpu hp_proliant_temp hp_sts_drvbox dell_om_disks dell_om_sensors hr_fs fast_lta_volumes hp_proliant_cpu dell_om_esmlog hp_proliant_raid
################>8
Caching walk of .1.3.6.1.2.1.2.2.1.6
Running snmpwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.1.1.0
Running snmpwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.1.4.0
Running snmpwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.1.5.0
Running snmpwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.1.6.0
Running snmpwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.2.1.1.3.0
Running snmpwalk -v2c -c ‘public’ -m ‘’ -M ‘’ -Cc -OQ -OU -On -Ot 172.16.2.31:161 .1.3.6.1.4.1.2021.10.1.6
1 hp_proliant
1 hp_proliant_cpu
1 hp_proliant_da_cntlr
25 hp_proliant_da_phydrv
4 hp_proliant_fans
4 hp_proliant_mem
1 hp_proliant_power
2 hp_proliant_psu
3 hp_proliant_raid
35 hp_proliant_temp
2 hp_sts_drvbox
1 hr_cpu
4 hr_fs
1 hr_mem
5 if64
1 snmp_info
1 snmp_uptime
1 ucd_cpu_load
Hi Nathan,
2nd: WATO -> Host & service parameters -> Access to agents -> Legacy SNMP devices using SNMP v2c
HTH,
Marcel
