How exactly does the LDAP contact group sync work? The help says "Add user to
all contactgroups where the common name matches the group name". This means to
me, that the name (not alias) of the group must match the LDAP field "cn". Is
this correct?
I've created a contact group in WATO called "NetworkAdmins" (Name and Alias is
the same). But users in this group are not added to the corresponding contact
group. The LDAP group looks like this:
I think you got it right. One thing to notice is, that you have to configure the "LDAP Group Settings" correctly. Only groups below the given "Group Base DN" can be found by the plugin.
What kind of LDAP are you using? Which server in which version?
Regards
Lars
this correct?
I've configured "ou=Groups,dc=domain,dc=ch" as Base DN and
"(objectclass=groupOfUniqueNames)" as filter. Trying this query with
ldapsearch gives me the desired resultset.
It's OpenLDAP in version 2.4.23.
Is there a logfile or debug setting which I can see what's going on during
matching?
Cheers,
Tobias
Nine Internet Solutions AG, Albisriederstr. 243a, CH-8047 Zuerich
Support +41 44 637 40 40 | Tel +41 44 637 40 00 | Direct +41 44 637 40 13
Skype nine.ch_support
I just had a look at the function "ldap_user_groups" in "ldap.py", there is a
LDAP filter (&(member=%s)) which does not match on our implementation of LDAP
groups. For us it should be (&(uniqueMember=%s)). What do you think of this?
Maybe there should be a field where we can configure which filter should
apply?
to all contactgroups where the common name matches the group name". This
means to me, that the name (not alias) of the group must match the LDAP
field "cn". Is this correct?
is the same). But users in this group are not added to the corresponding
contact group. The LDAP group looks like this:
