I’m trying to use the LDAP feature of cmk and have yet to get it to work. Maybe someone else has resolved a similar situation.
Our LDAP (openldap v3) uses TLS and listens on the regular port 389. From the command line I can connect as expected. However, when I put these same values in WATO, I get an error stating “confidentiality required
This works as expected on the server. The “-Z” starts the TLS request. It doesn’t look like python-ldap is starting the TLS and I don’t see an option in checkmk to provide this option. Thanks in advance for any ideas to help resolve this.
Check_MK currently does not support STARTTLS on LDAP. You can use SSL on
Port 636 to get the LDAP connection encrypted.
Regards
Am 16.03.2018 um 20:31 schrieb Spencer Butler:
Robert Sander
Heinlein Support GmbH
Tel: 030 / 405051-43
Fax: 030 / 405051-19
Zwangsangaben lt. §35a GmbHG:
HRB 93818 B / Amtsgericht Berlin-Charlottenburg,
Geschäftsführer: Peer Heinlein -- Sitz: Berlin
Check_MK currently does not support STARTTLS on LDAP. You can use SSL on Port 636 to get the LDAP connection encrypted.
Is there a timeline for STARTTLS support? Using ldaps is not an option in our environment.
Regards
-----Original Message-----
From: checkmk-en [mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Robert Sander
Sent: Saturday, March 17, 2018 05:39
Subject: Re: [Check_mk (english)] LDAP over TLS
This works as expected on the server. The "-Z" starts the TLS request.
It doesn't look like python-ldap is starting the TLS and I don't see
Robert Sander
