Hi everyone,
I have 2 check_mk servers. One with multisite configured and another. When the local server can not reach the other (switch/router down), i have a timeout message but maybe after 10-15 min and i can not do anything on the webui. It’s freezing.
So my question is : where can i erase the timeout, in order to prevent the webui bugging ?
Version : 1.2.2p1
Best regards.
Hi Sebastien,
you can define a status host on your livestatus connection. This status host is located on your local site and test the availability of your remote site with ping or something else.
If this status host is down (switch/router down) then livestatus will not try to reach the other server and the local GUI stays usable.
Best regards
Andreas
BOURLES, Sebastien sebastien.bourles@capgemini.com schrieb am Di., 20. Juni 2017 um 15:08 Uhr:
Hi everyone,
Version : 1.2.2p1
Best regards.
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
checkmk-en mailing list
Hi Andreas,
And if it’s the remote server which is down ? My local webui will still receive a timeout from the remote server and will bug. What
i would like to do is to declare the remote server as a status host. But as you said, it has to be a host on the local server.
Best regards.
Envoyé : mercredi 21 juin 2017 13:51
Hi Sebastien,
Best regards
Andreas
Hi everyone,
10-15 min and i can not do anything on the webui. It’s freezing. So my question is : where can i erase the timeout, in order to prevent the webui bugging ?
Version : 1.2.2p1
Best regards.
A normal setup with distributed hosts would look like the following
Central server: host1 (central server itself) , host2_status (status host for the remote site - with IP from remote host checked on central server)
Remote server host2 (real remote host) and any other hosts checked from this site
Livestatus on central server is configured with host2_status as status host for remote site.
If remote site is not reachable the host2_status will go down and the local livestatus knows that the remote site is not available anymore. The web gui should not hang then.
For every remote site you create a status host on your central site and configure the livestatus with this status host.
Best regards
Andreas
BOURLES, Sebastien sebastien.bourles@capgemini.com schrieb am Mi., 21. Juni 2017 um 16:10 Uhr:
Hi Andreas,
Best regards.
De : Andreas Döhler [mailto:andreas.doehler@gmail.com]
À : BOURLES, Sebastien; checkmk-en@lists.mathias-kettner.de
Objet : Re: [Check_mk (english)] Livestatus multisite timeout
Hi Sebastien,
Best regards
Andreas
Hi everyone,
Version : 1.2.2p1
Best regards.
It worked J
Thank you for your help ,
Best regards
Envoyé : mercredi 21 juin 2017 16:16
Best regards
Andreas
Hi Andreas,
remote server and will bug. What i would like to do is to declare the remote server as a status host. But as you said, it has to be a host on the local server.
Best regards.
Hi Sebastien,
Best regards
Andreas
Hi everyone,
Version : 1.2.2p1
Best regards.
