[Check_mk (english)] Livestatus vs Reality
Hi guys.
Can you explain the following?
QUERY:
GET services
Columns: host_name description plugin_output
Filter: description ~ ^Filesystem
Among the result i see:
LDBM-PRDE001;Filesystem /;OK - USED: 56.3% [7.31 GB], FREE: 43.7% [5.68 GB], TOTAL: 12.99 GB, (levels at 75.00/85.00%), trend: +2.43 GB / 24 hours, inodes available 13604k/99.81%
LDBM-PRDE001;Filesystem /opt;OK - USED: 0.065% [33.28 MB], FREE: 99.9% [49.96 GB], TOTAL: 49.99 GB, (levels at 75.00/85.00%), trend: 0.00 B / 24 hours, inodes available 52428k/100.00%
LDBM-PRDE001;Filesystem /var;OK - USED: 2.31% [1.15 GB], FREE: 97.7% [48.84 GB], TOTAL: 49.99 GB, (levels at 75.00/85.00%), trend: +448.63 MB / 24 hours, inodes available 52426k/100.00%
But, the server is DOWN. 2 hours ago. Is there a way to FILTER the DOWN servers?
THANK YOU!!!
Hi Gerardo,
Try adding this to your query:
Filter: host_state = 0
If that does not work (I don’t know the exact column and currently have no system to test) search for the column by this query:
GET columns
Filter: table = services
…and grep for “state”.
HTH,
Marcel
Gerardo Ferreyra raptorg83@gmail.com schrieb am Do., 14. Juli 2016 21:48:
Hi guys.
QUERY:
GET services
THANK YOU!!!
checkmk-en mailing list
host_state = 0. Superb.
Thanks!
2016-07-14 18:02 GMT-03:00 Marcel Schulte schulte.marcel@gmail.com:
Hi Gerardo,
GET columns
HTH,
Marcel
Hi guys.
QUERY:
GET services
THANK YOU!!!
