[Check_mk (english)] Local check script error
Headache issue, hope someone can spot my (stupid) mistake. I’m running standalone 1.2.3i6 on CentOS 6.4
I have some scripts, which simply do ps and grep to see if some proc count is good. It has been acting not as expected.
Here is the simple dummy script which is based on a simple skeleton:
#!/bin/bash
STATUS=‘0’
ITEMNAME=‘all_badboys-NY.pl’
VARNAME=‘Count’
COUNT=$(ps -ef|grep perl|grep all_streamPRO-NY4.pl|wc --lines)
WARN=’’
CRIT=’’
MIN=’’
MAX=’’
if [ $COUNT -eq 0 ]; then
STATUS=2
STATUSTXT=‘CRITICAL’
else
STATUS=0
STATUSTXT=‘OK’
fi
CHKOUTPUT="$STATUSTXT - $ITEMNAME process = $COUNT"
echo “$STATUS $ITEMNAME
$VARNAME=${COUNT};$WARN;$CRIT;$MIN;$MAX $CHKOUTPUT”
Running the script manually gets this:
/usr/lib/check_mk_agent/local # ./test1.sh
0 all_badboys-NY.pl Count=1;;;; OK -
all_badboys-NY.pl process = 1
However, when I run a Full service scan under WATO, I get
CRITICAL - all_badboys-NY.pl process =
0
What’s wrong?
Will
Hi Will,
seems as if no such process is running when scan is done, so no
problem with the check.
What does 'cmk -d HOSTNAME' output regarding the check?
BTW: Why don't you use the shipped ps check
(http://mathias-kettner.de/checkmk_check_ps.html)?
Regards,
Marcel
2013/11/21 William Kwan <potatok@yahoo.com>:
Headache issue, hope someone can spot my (stupid) mistake. I'm running
#!/bin/bash
STATUS='0'
ITEMNAME='all_badboys-NY.pl'
VARNAME='Count'
WARN=''
CRIT=''
MIN=''
MAX=''
   STATUS=2
   STATUSTXT='CRITICAL'
else
   STATUS=0
   STATUSTXT='OK'
fi
echo "$STATUS $ITEMNAME $VARNAME=${COUNT};$WARN;$CRIT;$MIN;$MAX $CHKOUTPUT"
0 all_badboys-NY.pl Count=1;;;; OK - all_badboys-NY.pl process = 1
CRITICAL - all_badboys-NY.pl process = 0
What's wrong?
Will
checkmk-en mailing list
I just figured out how to use the shipped ps check and we started to use it.
For our script, I'm very sure that the target proc has been running. Manually running the script would return OK, but check_mk will say no. I'll try collect the info you requested.
W
On Nov 20, 2013, at 9:52 PM, Marcel Schulte <schulte.marcel@gmail.com> wrote:
Hi Will,
Regards,
Marcel
#!/bin/bash
STATUS='0'
VARNAME='Count'
WARN=''
CRIT=''
MIN=''
MAX=''
  STATUS=2
else
  STATUS=0
  STATUSTXT='OK'
fi
What's wrong?
Will
