[Check_mk (english)] Local Plugin
Hi All
I have written a local check for our emc, however if I run this as a local check it will be populated in the wrong host, is there away to run the local check but for another host?
For Example:
Check runs on london-01, when we do a scan it would show under london-01, however I need it to show under storage-01.
Do I need to create this as a proper plugin so I can tag so it is populated under the correct host?
Thanks
Chris.
Hi Chris,
You could try it with piggyback feature. For that your local check output must report this:
(normal output here)
Name your local check file the way so it’s executed after all “real” local checks, like “zzz-mylocalcheck”.
I don’t know if that works with local checks, too, but for other checks all between “<<<>>>” and “<<<<>>>>” is treated as data of the foreign host.
Don’t forget to inventorize storage-01 as well as london-01 and apply changes.
Regards,
Marcel
Chris Owen chris.owen@8x8.com schrieb am Do., 31. März 2016 15:27:
Hi All
For Example:
Thanks
Chris.
checkmk-en mailing list
Hi Marcel
This is working as expected.
Thank you so much.
Chris.
On Thu, Mar 31, 2016 at 2:42 PM, Marcel Schulte schulte.marcel@gmail.com wrote:
Hi Chris,
Regards,
Marcel
Hi All
For Example:
Thanks
Chris.
