[Check_mk (english)] logfile patterns with WAT
I am trying to use logfile patterns with WATO … with no success
I monitor Windows hosts and as an example would like to ignore (or ok) all messages “ CRIT - unacknowledged messages have
exceeded max size, new messages are dropped (limit 500000 Bytes)”
So I defined a simple rule (see below) with “unacknowledged messages have exceeded max size, new messages are dropped” as pattern and set “CRITICAL” in the state .
Then I reclassify Critical state to OK.
When I test with analyzer it seems ok.
But then all those log lines are still critical, they do not switch to OK.
What is wrong?
Regards
Stephane
What is wrong?
Regards
Stephane
This is not a log message that is collected from the host but a critical
error generated on the monitoring server to tell you that there are too
many log messages in the cached logfile.
Thus it cannot be reclassified.
Regards
all messages “CRIT - unacknowledged messages have exceeded max size,
Robert Sander
Heinlein Support GmbH
Tel: 030 / 405051-43
Fax: 030 / 405051-19
Zwangsangaben lt. §35a GmbHG:
HRB 93818 B / Amtsgericht Berlin-Charlottenburg,
Geschäftsführer: Peer Heinlein -- Sitz: Berlin
Hi Robert,
Of course you are right... it is not an event viewer error.
Anyway is there a simple solution (I would prefer with WATO) to ignore automatically all logfile critical/warning messages (application, security, system,..)
I would like to deactivate for a while all alerts concerning Windows logfiles.
Regards
Stephane
-----Original Message-----
From: checkmk-en [mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Robert Sander
Sent: 30 April 2018 13:49
Subject: Re: [Check_mk (english)] logfile patterns with WAT
I am trying to use logfile patterns with WATO ... with no success
all messages "CRIT - unacknowledged messages have exceeded max size,
new messages are dropped (limit 500000 Bytes)"
This is not a log message that is collected from the host but a critical error generated on the monitoring server to tell you that there are too many log messages in the cached logfile.
Regards
Robert Sander
Join our #WithRefugees<http://www.unhcr.org/refugeeday/petition/&gt; campaign
Sign the petition today
You can tell the agent to not send Eventlog entries in the first place:
Unfortunately this is not documented at all except for the example ini file:
http://git.mathias-kettner.de/git/?p=check_mk.git;a=blob;f=agents/windows/check_mk.example.ini;h=ae7addc9c8d4b5dc0d6f1b2c0c0bf94e0fc7aba0;hb=HEAD#l114
You would need a line
logfile * = off
in the [logwatch] section of the agent's check_mk.ini.
Regards
Robert Sander
You can still increase the size for all valid rules.
If you want to ignore all of them for awhile then make a rule to ignore them via WATO as described in the beginner guide from Marco, page 40.
Create 1 rule for each log file to ignore and then move the rule (even if temporarily) to the top. The line should simply be an ignore line with a blank pattern.
Now nothing will WARN or CRIT until you move them or remove them.
I never use the ini files on hosts, personally.
Brian
Reply: Stephane C. A. Pelhatre pelhatre@unhcr.org
Date: April 30, 2018 at 7:12:57 AM
To: Robert Sander r.sander@heinlein-support.de, checkmk-en@lists.mathias-kettner.de checkmk-en@lists.mathias-kettner.de
Hi Robert,
Of course you are right… it is not an event viewer error.
Anyway is there a simple solution (I would prefer with WATO) to ignore automatically all logfile critical/warning messages (application, security, system,…)
Regards
Stephane
Regards
Robert Sander
http://www.heinlein-support.de
Geschäftsführer: Peer Heinlein – Sitz: Berlin
Join our #WithRefugeeshttp://www.unhcr.org/refugeeday/petition/ campaign
checkmk-en mailing list
Just create a logwatch rule for windows hosts that reclassifies all entries as ok (.*)
You can keep that as the fallback rule and add less specific rules before it to catch
log entries you want to know about.
On 4/30/2018 8:11 AM, Stephane C. A. Pelhatre wrote:
Hi Robert,
Regards
Stephane
Regards
Robert Sander
Or, if you don’t want to put in logfile patterns, you can just as easily disable the rules for the log files to begin with. I don’t find one way to be faster than the other, and both are accomplished via WATO.
Reply: Brian Binder brianjbinder@icloud.com
Date: April 30, 2018 at 7:19:45 AM
To: Stephane C. A. Pelhatre pelhatre@unhcr.org, Robert Sander r.sander@heinlein-support.de, checkmk-en@lists.mathias-kettner.de checkmk-en@lists.mathias-kettner.de
page 40.
them.
Brian
pelhatre@unhcr.org
AM
Hi Robert,
Windows logfiles.
Regards
Stephane
Robert Sander
success
(or ok)
size,
Regards
Robert Sander
Join our
campaign
