I’m already using quite a similar configuration as you do.
So I’m looking for a way to ignore the failed connection attempt.
Von: Fred [mailto:aroc_gwada@yahoo.fr]
Gesendet: Dienstag, 28. Juni 2011 19:31
An: Ronney Meier Rorotec GmbH
Betreff: Re: [Check_mk (english)] logging of execution of check_mk and ssh command
As explained in a previous mail to Ronney, i solved datasource programs issues this way :
/etc/check_mk/main.mk :
# ssh tag to use ssh for monitoring with Check_MK
all_hosts = [
"myhost|tcp|ubuntu|linux|dmz|ssh" ,
datasource_programs = [
( "ssh -p 119 -l root <IP> check_mk_agent", ['ssh'], ALL_HOSTS ),
# you can also use :
# ( "ssh -l root <IP> check_mk_agent", ['dmz'], ALL_HOSTS ),
# ( "ssh -p 119 -l root -i /var/lib/nagios/id_rsa <IP>", [ 'linux' ] ),
# ( "ssh -p 119 -l root <IP> check_mk_agent", [ 'ssh' ] ),
You have to su nagios and export public key on host "myhost" (ssh on TCP port 119 here) :
su - nagios
# ssh-heygen -t rsa
ssh-copy-id "root@myhost -p 119"
Do not forget to export root public key too :
su - root
# ssh-heygen -t rsa
Otherwise you will not be able to run commands :
check_mk --flush myhost && check_mk -I myhost && check_mk -O
Do not try "ssh -l root -p 1022 -i /etc/check_mk/check_mk.key <IP>", it will not work...
I tried dozens of combinations...
Keep in mind you must have your ssh keys in Nagios home directory !
Ubuntu 10.04.2 LTS Server
Nagios® Core™ Version 3.2.3
Nagios and the other packages compiled from source.
It also works with precompiled packages from my Ubuntu distro.
No more than half an hour to setup Nagios/Check_MK/Nagvis/PnP4Nagios. Tuning Mathias tool takes more time but it's worth !
Sorry if I misunderstood the probllem.
Bye.
Ronney Meier Rorotec GmbH a écrit :
`Hi mathias`
`You were completly right about the ssh connection failing, there is no`
`log`
`at all :-(.`
`ok you need to debug that first - that's an issue outside of check_mk.`
`Of course you could start with a legacy check that monitors ping & ssh to the`
`monitored host :>`
`Well ping wouldn't work, the gateway is configured not to respond on pings, but the host availability checks are made over check_tcp and this one never fails. It's only the ssh connection which fails from time to time. Even I never had problems with manual ssh connections. I'm running a script since 4 hours which executes the datasource_program every minute but I didn't get any error so far.`
`As far as I can guess it's propably a problem with the router there, which I can not influence, so I'm just trying to ignore the error ;-).`
`As far as I understand the caching agent, using it will result in the same problem, it will just query the hosts less frequent, but if this query fails I will have the same problem again...`
`You could expand your datasource_program to handle the return code so`
`that it returns an "UNKNOWN"?`
`I tried to do that with a datasource_program entry of`
`ssh -l root -p 1022 -i /etc/check_mk/check_mk.key <IP> ; exit 3`
`which doesn't work, after looking at get_agent_info_program in chech_mk_base.py it looks like it will raise an error as soon as the exit code is different from 0.`
`Is there another way to do it, or did I misunderstood you completely? ;-)`
`Thanks already`
`Ronney`
`I just wasn't able to find out what the caching agent is. Could you`
`maybe`
`give me a hint where I could find it?`
`About the caching agent:`
`It's a agent that doesn't do all commands each time it runs, instead it first`
`checks if the results are still fresh enough and then just sends you the cached`
`data from its last run.`
`(I didn't yet use it myself since I just didnt need it) There should be a`
`agent.tar.gz or a agents directory on your nagios server.`
`Look either in /usr/share/check_mk or in`
`/opt/omd/versions/default/share/check_mk`
`for a directory called "agents".`
`In there you should find check_mk_agent.linux.`
`As said before, it cannot fix your SSH issue, it can just ease the pain.`
`Florian`
`Mathias Kettner GmbH | \/ | |/ / M A T H I A S K E T T N E R`
`Florian Heigl | |\/| | ' /`
`Steinstr. 44 | | | | . \ Linux Beratung & Schulung`
`81667 München |_| |_|_|\_\ [http://mathias-kettner.de](http://mathias-kettner.de)`
`Tel.: 089 / 1890 4210`
`Fax.: 089 / 1890 4211 Mail: fh@mathias-kettner.de`
`_______________________________________________`
`checkmk-en mailing list`
`checkmk-en@lists.mathias-kettner.de`
`[http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en](http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en)`
