Hi all, my check is for greater than 1 file in the “/opt/files/” directory. There are 2 files in that directory but the check is reporting status ok.
Can anyone suggest how I might be able to progress this please?
Regards,
WILL
Sent: 07 January 2015 18:56
To: ‘checkmk-en@lists.mathias-kettner.de’
Subject: RE: file count check
Hi, I’ve managed to make some small progress, the agent is definitely looking in the correct folder as the 2 files are showing in the list of services for the host, which is not what I want. Also the check that
I do want (file count > 1) appears to be checking age oldest, age newest, size and count, yet I have only selected the count check box within the rule settings. This is all very confusing, if anyone out there can shed some light on this I’d be very grateful.
Regards,
WILL
Sent: 07 January 2015 16:56
Subject: file count check
Hi folks, can anyone give me some information on how to debug this file count check please? I’m using WATO and have taken all required steps, my monitor should be reporting critical error but its reporting status ok.
My check is for > 1 file in the “/opt/files/” directory and there are 2 files in that directory. So, I’m thinking my check isn’t looking in the right place.
How can I figure out where the agent is actually looking? The link below is exactly the same problem as I’m having but unfortunately is not resolved.
Regards,
WILL
p.s. Marcel if you see this email it’s the same piece of work that you were helping me with a couple of days ago so please disregard previous email
J
William Roach
Watchtower Support Manager, End User Technology & Security
BT Technology, Service & Operations
| Tel: 01225818185 or 07436 278627 |
william.roach@bt.com |
http://fixit.bt.com
BT Group plc Registered office: 81 Newgate Street London EC1A 7AJ. Registered in England and Wales no. 4190816 This electronic message contains information from BT Group
plc which may be privileged or confidential. The information is intended to be for the use of the individual(s) or entity named above. If you are not the intended recipient be aware that any disclosure, copying, distribution or use of the contents of this
information is prohibited. If you have received this electronic message in error, please delete it and notify me immediately by telephone or email.
